proportioning valve help
Old Oct 25, 2007 | 01:50 PM
chelude's Avatar
Default proportioning valve help
I am in the process of replacing my brakes on my 1995 civic cx hatchback , I just replaced my front brakes with a wilwood 12.19 four piston brake kit, and changed the rear drum brakes to eg6 disc brakes, I used a type r master cylinder and I need to know what the best or easist proportioning valve is to install with my set up?
Old Oct 25, 2007 | 03:06 PM
toolfanholle's Avatar
Default Re: proportioning valve help (chelude)
I'm not sure if you need anything special with the oversized front brakes, but when i converted to rear disks i used a prop valve from an DC2 integra. i don't think it matters what model. you also should be able to use one from a ek or eg civic si.
Old Oct 25, 2007 | 03:15 PM
philosofy1's Avatar
Default Re: proportioning valve help (toolfanholle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolfanholle &raquo;</TD></TR><TR><TD CLASS="quote">I'm not sure if you need anything special with the oversized front brakes, but when i converted to rear disks i used a prop valve from an DC2 integra. i don't think it matters what model. you also should be able to use one from a ek or eg civic si.</TD></TR></TABLE>
no not entirely true. if you did use the prop valve off of a DC2 it can only had been from one that was non abs, which i believe was 94-95 rs models. all the others have abs and the prop valve is not compatible.
being that the op has a 95 cx, all 92-95 civic (non abs) have the 3030 prop valve, and the ek aren't compatible due to the way the lins are ran.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chelude &raquo;</TD></TR><TR><TD CLASS="quote">I am in the process of replacing my brakes on my 1995 civic cx hatchback , I just replaced my front brakes with a wilwood 12.19 four piston brake kit, and changed the rear drum brakes to eg6 disc brakes, I used a type r master cylinder and I need to know what the best or easist proportioning valve is to install with my set up? </TD></TR></TABLE>
go to any junk yard that carries hondas. look for any 90-93 integras (DA). they are the most commonly used when it comes to the 4040 prop valve. which is the valve that you need.
Old Oct 25, 2007 | 03:43 PM
BlueIntegraBoy's Avatar
90-93 Integra non-ABS
94-95 Integra RS
Will say 4040 on it.
Old Oct 25, 2007 | 05:33 PM
chelude's Avatar
Default Re: proportioning valve help (BlueIntegraBoy)
thanks fellas, are there any from honda instead of acura?
DomkeBoy
Jun 10, 2011 05:47 AM
SideFX
18
May 4, 2011 12:31 PM
StolenTeg
Oct 2, 2006 01:05 PM
TeachHist2005
Nov 15, 2003 07:44 PM
buck02
Apr 24, 2003 08:05 PM
