average GSR gas mileage???
Old Oct 25, 2007 | 01:38 PM
GSRBrent's Avatar
Default average GSR gas mileage???
i dont know if its how i drive my GSR but i dont seem to get the gas mileage i should whats the average and what should i check on to improve intake,fuel pump?
Old Oct 25, 2007 | 02:26 PM
-DC2-'s Avatar
Default Re: average GSR gas mileage??? (GSRBrent)
see my avatar
Old Oct 25, 2007 | 02:53 PM
all-mtr-teg's Avatar
I get about 30 on the freeway, and that sucks compared to my homeboy who's got a b20vtec running 15psi and 550 cc injectors in a 95 civic coupe getting 37mpg.
Old Oct 25, 2007 | 03:52 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: average GSR gas mileage??? (all-mtr-teg)
Bone stock '94 GS-R, we get 24-26 mpg in mixed local and highway driving, 29-33 mpg on long trips with few stops.
Old Oct 25, 2007 | 03:55 PM
aaronISthrowed's Avatar
Default Re: average GSR gas mileage??? (nsxtasy)
I get about 28 mpg city driving my boosted gsr.
Old Oct 25, 2007 | 04:02 PM
thewrai6th's Avatar
Default Re: average GSR gas mileage??? (aaronISthrowed)
22-24MPG
vvvv
Old Oct 25, 2007 | 04:04 PM
TightEyez's Avatar
Default Re: average GSR gas mileage??? (thewrai6th)
around 20mpg, all city driving in rush hour traffic, and thats with me not hitting vtec alot
Old Oct 25, 2007 | 04:13 PM
kweezerkwee's Avatar
im trying to figure out how much im getting but im guessing around 25 mpg mixed
Old Oct 25, 2007 | 05:37 PM
TunerN00b's Avatar
Default Re: average GSR gas mileage??? (TightEyez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TightEyez &raquo;</TD></TR><TR><TD CLASS="quote">around 20mpg, all city driving in rush hour traffic, and thats with me not hitting vtec alot </TD></TR></TABLE>
Same here. Traffic kills mileage. 19-23 mpg on my daily commute(6.7 miles each way), averaged out over entire tanks.
Hit 32, as my highest mileage ever, and that was pure freeway driving with a two stops in total.
Almost enough to make me start commuting in my Spitfire. That crazy car is capable of 40 mpg in pure city driving, and has actually managed a 50+ mpg average for a few tanks of mixed driving. Except, no power anything (not even steering or brakes), no airbags, no AC, and no side impact protection at all (doors are empty shells with a window in them, the glass offers more protection than the door panel).
Old Oct 25, 2007 | 05:38 PM
GSRBrent's Avatar
Default Re: (kweezerkwee)
what can i do to quickly improve?
Old Oct 25, 2007 | 05:55 PM
-DC2-'s Avatar
Default Re: (GSRBrent)
if your o2 sensor has over 50k on it, install a new one. re-set ECU after.
Old Oct 25, 2007 | 06:17 PM
NUISANCE's Avatar
I got around 32mpg before rebuilding the motor and now I get 29-30 after my rebuild/build up.
Old Oct 25, 2007 | 06:57 PM
gsr98integra's Avatar
My car gets between 26 and 28 mpg intown depending on how much vtec I use and 34 mpg on the interstate.
You could do the basic tune up stuff like spark plugs, spark plug wires, cap and rotor... use some injector cleaner maybe? Idk if a new fuel filter would help but if it hasn't been replaced in a while you could try that.
good luck!
Old Oct 25, 2007 | 07:44 PM
beastman@'s Avatar
Default Re: (gsr98integra)
BRENT, what's up dude it's Brent. I get about 30k highway and 25city with my 98 GS-R.
Brents are rare, Brents with integras, even more rare
Brents with an integra GS-R, we might be the only two in the world.
Old Oct 25, 2007 | 07:50 PM
1fstdc2's Avatar
i got a boosted gsr pushin 300+ whp and it gets 22-24 mpg on average with couple of races in between... oh yea it i also have a ctr tranny..
Old Oct 25, 2007 | 08:36 PM
vtec8804's Avatar
* B A N N E D *
the best milage i ever got in my gsr was all highway 290 to a full tank... i average 24-26 thou driving around the twpship
Old Oct 25, 2007 | 10:11 PM
berettagtz117's Avatar
29-38 city high..
Old Oct 25, 2007 | 10:16 PM
98BabiGs-T's Avatar
Default Re: (berettagtz117)
36 MPG - All highway
27 MPG - All city
30ish MPG - Mixed
Bone stock Gs-R. My LS does about 1 MPG better same settings.
Old Oct 26, 2007 | 01:41 AM
-DC2-'s Avatar
Default Re: (98BabiGs-T)
if you have removed the OEM under-body panel that covers between the radiator support and engine, re-install it. i have proven a 4mpg loss without it.
also, if you have a half-style civic radiator, and no A/C condensor, install a block off plate to cover the opening.
Old Oct 26, 2007 | 06:00 AM
OH_1fstgsr's Avatar
Default Re: (-DC2-)
Most recently: Worst 20mpg
Best 32mpg
GSR built with ITR parts, ~190whp.
Best ever 38mpg with I/H/E 100% Highway.
Old Oct 26, 2007 | 08:48 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRBrent &raquo;</TD></TR><TR><TD CLASS="quote">what can i do to quickly improve?</TD></TR></TABLE>
1. As gsr98integra recommends, keep your car well-maintained. I suggest following the maintenance interval recommendations in the owner's manual and service manual at a minimum.
2. Your driving style effects your mileage. Hard acceleration, and frequent acceleration and braking, reduce your mileage. So if you're doing jackrabbit starts at stoplights, that hurts. So does driving in stop-and-go commuter traffic. Driving at extreme high speed hurts, too. And for the best mileage, keep your car in the highest gear you can without lugging the engine. Of course, some of these things can be fun , but you asked how to improve your mileage.
3. Check your tire pressures periodically. As a general rule, setting them to the pressures recommended by your car's manufacturer (as found in your owner's manual and on the door jamb) is the best place, at least to start out; adjust as needed. (Do NOT set them to the maximum PSI indicated on the tire's sidewall, which is a capacity limitation, not a recommendation.)
sinister357
Aug 22, 2007 08:01 AM
peel17
Oct 21, 2005 12:44 PM
vtech1
Mar 24, 2005 11:13 PM
grlstockb18c1
May 17, 2003 07:05 PM
B18Redline
Oct 11, 2002 09:09 PM
