Eibach Sport Lines...Need help with the rear bump
I'm getting this popping sound on both sides in the front when I turn (either way) and on bumps.
What's causing this?
I just finished putting on Eibach Sportlines on my si sedan and the rear has like 2 1/2 finger gap and fronts have about 1 1/2 finger gap....
Did you cut the rear bump stops? I remember reading something about drilling? I looked over the other DIY but didn't see anything.
Modified by lando griffin at 6:05 PM 10/25/2007
I only cut the front on mine because i didn't want to drill anything and my ride height is even front back hopefully everything was installed correctly
Sometimes the front will settle faster then the rear etc give it a week or 2 you should be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WILD_WILL »</TD></TR><TR><TD CLASS="quote">I only cut the front on mine because i didn't want to drill anything and my ride height is even front back hopefully everything was installed correctly
Sometimes the front will settle faster then the rear etc give it a week or 2 you should be fine.</TD></TR></TABLE>
Lol I think I just pmed you over on 8th
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WILD_WILL »</TD></TR><TR><TD CLASS="quote">LOL i think so 2
haha. Do you have any pictures of your car?
</TD></TR></TABLE>haha. Do you have any pictures of your car?
Let me see if i can find something i had some really good 1's a freind took but then they were deleted off his photo bucket !
Crappy pics but oh well - In person its dead even i can hardly get a finger in front or back almost tucked but not lol i also have 3 friends with the same springs and they are fine as well
1 week its funny because a week after i put them on my car was almost totaled by a 18 wheeler so i never even got an alignment before i was hit but it handled alot better and was more planted in corners. I would be patient with it it happens if worse comes to worse just go over the rear install again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WILD_WILL »</TD></TR><TR><TD CLASS="quote">1 week its funny because a week after i put them on my car was almost totaled by a 18 wheeler so i never even got an alignment before i was hit but it handled alot better and was more planted in corners. I would be patient with it it happens if worse comes to worse just go over the rear install again
Yeah I remember seeing that thread
But yeah, I can't drive right now anyways, I dropped a socket in the little pocket thing where the top nuts are for the front shocks. Waiting for a ride to get a little magnetic stick
</TD></TR></TABLE>Yeah I remember seeing that thread
Ok got it out but now I got another problem...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Caveman74 »</TD></TR><TR><TD CLASS="quote">did you alighn the arrows forward on the tophat?</TD></TR></TABLE>
Doing it now...is the arrow supposed to face towards me or away?
Also when putting the spring back into the top "spring seat" are you supposed to make twist all the way around?
Both arrows are now facing the engine/frame and I also torqued everything down to fct. spec this time lol.... I think also had both the top and bottom spring seat on wrong
It's too damn cold and dark right now, but test drive comes t/m.
Would that cause it to make popping noises?
