Trans filler hole?
Old Oct 25, 2007 | 09:32 AM
DrivinVtec's Avatar
Default Trans filler hole?
I just read DIY fluid change on a h22. last time i did it I used pump under the car. but this guy said soemthing about filling from the top? do u use that breather hole thing with rubber top? is that where he filled it up at?
Old Oct 25, 2007 | 10:14 AM
Finest's Avatar
Default Re: Trans filler hole? (DrivinVtec)
The "proper" way to do it is to use the fill hole on the side of the transmission. This ensures that you'll fill it up correctly (until it runs out from the fill hole). Otherwise, you can drain the transmission and put in 1.9L of MTF through the vent hole.
Old Oct 25, 2007 | 11:39 AM
A Blue Lude's Avatar
Vent hole does work.
Old Oct 25, 2007 | 12:21 PM
Eddiebx's Avatar
or if u find it too hard to get it into the tiny vent hole, u can also just usncrew the revers switch, and fill it through there, the opening is much larger,
i usually just drain it, then fill in 2qts, since most of the time when i do it the proper way, after filling 2qts only a tiny bit overflows. so i guess that tiny bit extra in there shouldnt matter too much, haha
Old Oct 25, 2007 | 12:41 PM
DrivinVtec's Avatar
for the revers..you talking about the 3 screws? it has a plug ontop?
Old Oct 25, 2007 | 01:01 PM
DrivinVtec's Avatar
also is the drain hole the squar one? an the big bolt (17mm I thin) behind the axel is the hole i look at while im pouring?
Old Oct 25, 2007 | 01:11 PM
DrivinVtec's Avatar
up
luv2boost
Aug 8, 2007 10:06 PM
imadigitalgod
Oct 22, 2004 08:33 AM
Slow89HB
Oct 9, 2004 04:48 AM
Understeer
Mar 19, 2004 09:59 AM
Cyberdx16
Mar 3, 2004 02:53 AM
