Code 43.....What could it be??
Old Oct 24, 2007 | 09:13 PM
xanonymousx's Avatar
Default Code 43.....What could it be??
First, I have a crx with an obd-0 b18b1 in it. I keep getting code 43 and I can't seem to figure it out. Anybody have any idea what it could be? Here is a list of stuff I've done:
Checked:
plugs
wires
timing
Replaced:
distributor
o2 sensor
map sensor
tps
fuel filter
Old Oct 24, 2007 | 09:31 PM
2slow4stock's Avatar
Default Re: Code 43.....What could it be?? (xanonymousx)
Use the search funtion... It will help you out in the long run.
But since i'm here anyways Code 43 is Fuel supply system.
Old Oct 24, 2007 | 09:40 PM
Default Re: Code 43.....What could it be?? (2slow4stock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2slow4stock &raquo;</TD></TR><TR><TD CLASS="quote">Use the search funtion... It will help you out in the long run.
But since i'm here anyways Code 43 is Fuel supply system. </TD></TR></TABLE>
Um, so I need to replace the fuel supply system? Anyhow, I am very aware that code 43 is fuel supply system but I need to know what part of the fuel supply system could be causing this. Next
Old Oct 25, 2007 | 10:48 AM
jdm_titan's Avatar
look in your car check the basic fuel components
Old Oct 25, 2007 | 01:38 PM
Default Re: Code 43.....What could it be?? (jdm_titan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_titan &raquo;</TD></TR><TR><TD CLASS="quote">look in your car check the basic fuel components </TD></TR></TABLE>
I have and the fuel system seems to be fine
Old Oct 25, 2007 | 01:40 PM
akandok's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xanonymousx &raquo;</TD></TR><TR><TD CLASS="quote">
I have and the fuel system seems to be fine </TD></TR></TABLE>
If its fine you shouldnt be getting the code
Old Oct 25, 2007 | 01:42 PM
akandok's Avatar
https://honda-tech.com/zerothread?id=2018879
Google does wonders
Old Oct 25, 2007 | 01:44 PM
akandok's Avatar
did you use a new o2 sensor?
Old Oct 25, 2007 | 01:58 PM
Default Re: (akandok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akandok &raquo;</TD></TR><TR><TD CLASS="quote">did you use a new o2 sensor?</TD></TR></TABLE>
Ya, a new denso. Ok, I think I got it to go away. I reset the ecu and drove it around for a little bit and it has yet to come on. Thanks guys
godixon
Mar 28, 2014 03:56 AM
dirk digler
Jan 25, 2009 04:44 PM
Rhythmsnewsn
Sep 4, 2006 03:30 PM
PhilStubbs
Jan 22, 2005 11:20 AM
oO
Apr 10, 2003 07:03 AM
