i have a clutch issue
Old Oct 24, 2007 | 09:08 PM
latino honda's Avatar
Default i have a clutch issue
i am stuck i put a b18a in my crx and the cable for the clutch is to short so i went to autozone to match them up and all 88-91 civics are the same which is kind of odd so i checked a 4 door integra cuz that is what i took the cable bracket and it is even shorter than the civic cable the reason why it is odd cause my friends ef is longer than mine so what kind of clutch cable do i need
Old Oct 25, 2007 | 06:36 PM
JakeSpec's Avatar
Default Re: i have a clutch issue (latinohonda)
you can use the ef one you just need to cut an inch off the rubber around the cable where it connects to the trans bracket or just run a DA one and end the whole prob.
Old Oct 25, 2007 | 07:57 PM
Default Re: i have a clutch issue (JakeSpec)
does it matter if it is ls rs or gsr
Old Nov 1, 2007 | 09:48 AM
ok thanks
Ef4doorwagon
Feb 19, 2015 01:10 AM
djnikko
Jan 2, 2015 07:01 AM
Nutnwrench
Jun 18, 2008 08:55 PM
redboy183
20
Jan 1, 2008 07:05 PM
ExplicitSpeed360
May 3, 2006 06:08 PM
