wheel bearing
Old Oct 24, 2007 | 07:28 PM
jaskuloski97sh's Avatar
Default wheel bearing
i think my wheel bearing is going out. is it hard to replace. is there a instructions on how to do it
Old Oct 24, 2007 | 07:35 PM
dmpd_ef's Avatar
Default Re: wheel bearing (jaskuloski97sh)
i think if you remove the knuckle yourself and take it to a machine shop they can press the old one out and install the new one for you
Old Oct 24, 2007 | 07:42 PM
Default Re: wheel bearing (dmpd_ef)
ok thanks for the help
Old Oct 24, 2007 | 07:55 PM
is there in structions on how to do it
Old Oct 24, 2007 | 07:56 PM
dmpd_ef's Avatar
on removing the knuckle or pressing the bearing?
Old Oct 24, 2007 | 08:02 PM
i guess just everything the more info the better. i have to drive to chicago in a week or so and i dont want to stuck
Old Oct 24, 2007 | 08:13 PM
dmpd_ef's Avatar
you should try the search button bcuz sombody might have gone deeper into this matter. but as far as i kno, unbolt the a arm, tie rod & lower arm from the knuckle, remove the brake caliper and that should be it. then just take it to a machine shop along with the new bearing and ask them to press the old one out & the new one pressed in. but do try the search button just to be sure, good luck to you
Old Nov 28, 2007 | 09:21 AM
bow tie's Avatar
hey is all you need to do the install just the wheel bearing or do you need the whole hub assbly?
Old Nov 29, 2007 | 12:03 AM
brzrkr's Avatar
all you need is the wheel bearing, but you need the tools to press out the old one, i suggest taking the knuckle to a shop and let them do it, much cheaper than just taking your car there
Old Dec 4, 2007 | 06:18 PM
SEATownboi08's Avatar
I just got done with replacing mine outta 93 integra. I think they are sealed bearings as mine was buy a new one from parts store .. Then just take apart whole knuckle. Its not hard at all.
TegraD
Feb 26, 2008 06:13 AM
taylorjohnson11
Nov 14, 2007 07:40 PM
blueDAteg
Mar 25, 2007 10:25 PM
wrx'n you
Sep 16, 2006 11:30 AM
Civmochris
Nov 16, 2003 06:13 PM
