OEM CF hood. help!!
Old Oct 24, 2007 | 06:34 PM
Jbur074's Avatar
Default OEM CF hood. help!!
i just got a very cheap oem cf hood for my 2000 ek but it came without a hood latch.. i cant find any on ebay or anywhere.
and i do not want to drillholes for hood pins.
any help would be great! thanks in advance
Old Oct 24, 2007 | 06:38 PM
BlackoutVTi's Avatar
Default Re: OEM CF hood. help!! (Jbur074)
Okay, well then you'll just have to get the OEM hoodlatch, stick it on with 3M, and hope for the best I guess.
Dude, I think you're going to need to do it right and get it drilled. I know you don't want to drill, but what's the point if it's not going to be on the car safely?
Some pins would be recommended for safety.
Old Oct 24, 2007 | 06:39 PM
fatpride111's Avatar
go to a junk yard and get a hood latch for like 15 bucks...
Old Oct 24, 2007 | 06:46 PM
Jbur074's Avatar
Default Re: (fatpride111)
i cant find any at a junkyard.. i looked at my oem hood and latch is welded on therees not attachment....
i really dont like the look of hood pins :'(
the hood came with the holes and threads in it i just need the freaking latch!
Old Oct 24, 2007 | 06:47 PM
Default Re: (Jbur074)
Take it to your local shop and ask them what to do. I think that'd be the solution you're looking for.
Hood pins are for safety, not looks.....unless you're a ricer and you've drilled your OEM hood just to pin it. Even if you do get a latch installed, you should just consider some non-descript pins for the safety.
Old Oct 24, 2007 | 06:56 PM
ek-g6's Avatar
better safe than sorry, even if you get a hood latch and get it on there, what if it breaks? you might have to replace your windshield. go with the pins your wallet will thank you in the future when your going fast.
Old Oct 24, 2007 | 06:59 PM
Jbur074's Avatar
Default Re: (BlackoutVTi)
what about a hood damper kit?? would that not work?
Old Oct 24, 2007 | 07:02 PM
Hood damper kits usually come with a disclaimer, saying that they are not recommended for cars with carbon fiber hoods because damage is a possibility.
Plus, you're still left with your initial problem, as hood dampers do not lock the hood down, or hold it down in any way.
Old Oct 24, 2007 | 07:22 PM
Jbur074's Avatar
i knew you needed the latch, but i was under the impression that they held the the hood down
Old Oct 24, 2007 | 07:27 PM
Nah, they don't. They're just an alternative to the hood prop, for convenience and looks.
So, back to the latch/pins solution. I really don't know what else to tell you now, besides this:
Get both. Be safe. Good luck.
Sammy Park
Aug 27, 2018 09:00 PM
Slammed_am
Nov 6, 2010 07:09 AM
Jbur074
Oct 14, 2007 12:58 PM
IntegraGSR23
Nov 28, 2002 08:45 AM
AcuraFiend
Aug 20, 2002 05:01 AM
