99 - 00 ek convrsion question? gap between fender and headlight
Old Oct 24, 2007 | 06:29 PM
bigjay1six1's Avatar
Default 99 - 00 ek convrsion question? gap between fender and headlight
whats good people im new at this... i recently made my civic 1997 to a 99-00 front end and use did everthing the correct way, fenders, headlights, hood, grill and bumper. i even cut the piece that you didnt need on the radiator support.
now when i put everything together i realize that the headlight has a gap in between the headlight and the fender can anyone please help me if you need metop post pictue i will............. :
Old Oct 24, 2007 | 06:40 PM
BlackoutVTi's Avatar
Default Re: 99 - 00 ek convrsion question? gap between fender and headlight (bigjay1six1)
So, post a picture then. People are 10x more likely to click a thread if it has a picture anyway. Bump for some help, but I'd like to see a picture.
Old Oct 24, 2007 | 07:06 PM
Old Oct 24, 2007 | 07:07 PM
One with the hood up please?
Don't those headlights have any space to be pushed back a little bit?
Oh, and thank you for actually even going to get some pictures. A lot of people don't even bother.
Old Oct 24, 2007 | 07:10 PM
Default Re: 99 - 00 ek convrsion question? gap between fender and headlight (BlackoutVTi)
everything bolts right up and that how it end up looking
Old Oct 24, 2007 | 07:13 PM
BullJ07's Avatar
Are they OEM headlights?
Old Oct 24, 2007 | 07:16 PM
i mean it looks okay fron a distance but when you come up close you can tell right of te back and im tired of looking at 99 - 00 civic and the look perfectcompare to mine so i really want to fix this as soon as possible so your help would rally help me alot
i alrady heard that i need a new radiator support
then i heard that i need th upper tie bar of a radiator support
and the last on was that i need to grind something but i didnt pay that much attention i was to busy thinking about my car lol
every thinng tha i use was of a 99 civic hatchback
everythng is oem
Modified by bigjay1six1 at 8:35 PM 10/24/2007
Old Oct 24, 2007 | 07:20 PM
candyman206's Avatar
You don't need the support. All that needs to be done is cutting the tab by the grill and drilling your own hole.
JustG's Avatar
this seems like a nice lil upgrade to the front end. Do you have a few pics of the the whole front ed, from the front and the side??
And to help with your problem, how big are the gaps between the door and fender?
Kinda looks like you can move the fender forward a few mm and then adjust the h/light back a few mm and that should get you close. Never had/seen this but thats what I can come up with.
Any1 else have input on this mod for my own curiousity???
Old Oct 24, 2007 | 07:22 PM
Well, they don't look like they'd open up a gap between the headlights and the bumper if you brought them back about a 1/4". Why don't you just get a little creative? I'm not saying to do this if you have a problem with being "ghetto," but you could take the headlights out, and "adjust them" to fit the car's new contours.
I would suggest that you be a little more imaginative when it comes to a 1/4" distance. You may need to drill something.
EDIT: Upon closer inspection, it does look like your fenders could move forward the tiniest bit to line up properly with the bumper and hood.
Old Oct 24, 2007 | 07:33 PM
JustG's Avatar
Ya, thats what I was getting at too. Looks like the fender should come forward a bit.
Old Oct 24, 2007 | 07:39 PM
Default Re: 99 - 00 ek convrsion question? gap between fender and headlight (JustG)
i tried that
but a gap came between the door and the fender
Old Oct 24, 2007 | 07:51 PM
Use your imagination, you'll come to a solution. Just make sure it ends up clean.
Like I said, you MAY have to end up cutting/drilling a little bit more, but it'll work out for you in the end if you do it right.
zeke1982
Oct 20, 2009 03:36 AM
99evohonda05
May 15, 2005 08:05 PM
CarbonCreations
Jul 11, 2003 06:10 AM
