going to track tonight
Old Jun 21, 2002 | 11:46 AM
GRAVEDIGGER's Avatar
Default going to track tonight
have azenis tires andwas thinking about running 30psi in the front 50 in the rear also wondering if it is worth it to disconnect the power steering belt. thanks for any info..
Old Jun 21, 2002 | 12:47 PM
Incognito's Avatar
Default Re: going to track tonight (rp2000r)
Disconnexcting the power steering belt helps. Gave me 2hp to the wheels on the dyno.
50psi in the rear is good, but you may want to run the fronts lower, somewhere between 20 and 25psi.
Do a good 2nd gear burnout (dump the clutch at 7000rpms and let tires spin for a little bit). Launch around 5000rpms, slipping the clutch out.
Good luck.
DC 2
Aug 2, 2006 06:06 AM
577HondaPrelude
40
Sep 8, 2003 09:23 PM
TypeSH
Mar 25, 2002 04:54 PM
Toda Party
Dec 17, 2001 02:48 PM
90integraGS
Jun 18, 2001 08:16 PM
