h22 in 97 integra..which yr prelude shift linkage.
Old Oct 24, 2007 | 02:29 PM
h23vtecpowered's Avatar
Default h22 in 97 integra..which yr prelude shift linkage.
i bought a 97 integra with a h22 swap and i think the shift linkgae is gone because it want go into gear but i dont know what year shift linkage i need to get. any help would be great. thanks
Old Oct 24, 2007 | 06:22 PM
weavertime1's Avatar
Default Re: h22 in 97 integra..which yr prelude shift linkage. (h23vtecpowered)
ummmmmmmmmmmmmmm...H22a 's do not have linkages, unless you found one with an H2B swap. They are cable operated trannies
Repost if you have more info
Old Oct 24, 2007 | 06:43 PM
Default Re: h22 in 97 integra..which yr prelude shift linkage. (weavertime1)
yea its the cables. didnt know there was a difference..i know they have the cables and the bar but i thought it was referred to as the shift linkage. but anyway what yr. does anyone know
Old Oct 24, 2007 | 07:14 PM
Honda_Fanatic's Avatar
You can use cables from any 92-01 Prelude or 90-?? Accord! The 90-93 accords are a little shorter though but will work fine. (just not sure how long they would last)
Old Oct 24, 2007 | 07:39 PM
Default Re: h22 in 97 integra..which yr prelude shift linkage. (Honda_Fanatic)
i was told that the 97-01 wouldnt work because of some box
Old Oct 25, 2007 | 12:49 PM
up
Old Oct 25, 2007 | 02:26 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23vtecpowered &raquo;</TD></TR><TR><TD CLASS="quote">i was told that the 97-01 wouldnt work because of some box</TD></TR></TABLE>
the newer Preludes use a plastic shifter, do you have a metal one? I'm pretty sure any older accord or prelude will work fine if you have a metal one. Also, refer to the hybrid forum with these kinda questions for a quicker answer.
preludefien
Oct 16, 2007 07:59 AM
cpforyou
Dec 2, 2005 12:16 PM
Myh4tch
Apr 29, 2004 01:48 PM
F120man
May 13, 2003 06:46 AM
mr.wong
May 26, 2002 10:23 PM
