Need to lower HC during 15mph for smog
Old Oct 24, 2007 | 01:25 PM
all-mtr-teg's Avatar
Default Need to lower HC during 15mph for smog
Here are my numbers
15mph
CO2 = 14.9
O2 = 0.0
HC
Max = 61
Meas = 70
CO
Max = .54
Meas = .07
NO
Max = 467
Meas = 18
Should i retard timing, advance timing, run lower octane, higher octane, wider spark plug gap?
Old Oct 24, 2007 | 08:59 PM
dtapia's Avatar
Default Re: Need to lower HC during 15mph for smog (all-mtr-teg)
ok silly question how long has it been since a oil change ?
the failure is so close 9ppm is close what plugs do you have in it and please all mods and so forth
Old Oct 25, 2007 | 07:49 AM
Default Re: Need to lower HC during 15mph for smog (dtapia)
Brand new NGK Bkr6-11 gapped to 52, got about 200 miles since last oil change, but I was also running a mix of 91 and 100 octane. About 8 gallons 91 octane and 2 gallons 100 octane. GSR, bc3 cams, skunk2 IM, edelbrock 65 mm TB, AEM v2 intake, Edelbrock exhaust, 2.5" kteller exhaust
Old Oct 25, 2007 | 11:20 AM
trickeng's Avatar
running to rich. put some emissions pass additive from autozone, new #5 plugs stock gap and take it for a nice long ride before smog.
Old Oct 25, 2007 | 11:57 AM
Default Re: (trickeng)
running a hotter plug will lower HC? What about advancing or retarding timing?
Modified by all-mtr-teg at 1:12 PM 10/25/2007
Old Oct 25, 2007 | 02:25 PM
TunerN00b's Avatar
The simple solution.
I'm completely serious. Dropped my HC and NOx counts around 15% each on a dirty running 1988 Civic, and allowed me to pass.
Alternatively, ISO HEET
Which is just a gas line anti-freeze, and available at most Pep Boys or similar stores. Its alcohol, and burns clean, without producing HC. Since it burns cooler, ti also reduces you NOx.
Old Oct 25, 2007 | 02:37 PM
Default Re: Need to lower HC during 15mph for smog (TunerN00b)
yeah, i got 4 bottles of the heat, im gonna try that tomorrow during my pretest at the regular smog station. My state ref appt is on tuesday.
k20user
Aug 14, 2010 03:59 PM
07jdmfit
May 18, 2009 06:39 PM
Redtail
Nov 10, 2004 02:01 PM
matt j
20
Jun 10, 2003 09:39 AM
