idle high
Old Oct 24, 2007 | 01:17 PM
drewb16a's Avatar
Default idle high
hey ht....i got a b16 swao in my 92 4dr...i had got my car tuned about 2 months ago with chorme...the guy set my idle at 1000 and now my car is idling at 1500...and i hear a knocking nosie.when i press the clutch the knocking nosie stops and when the car is in gear and i press the clutch half way the knocking nosie stops and idle is normal....thanks for any help
Old Oct 24, 2007 | 01:22 PM
Bazza's Avatar
Default Re: idle high (drewb16a)
the knocking sound your hearing is your throw out bearing in your clutch i had the same problem but then i put a new clutch and bearings in and it was fine.that should fix the problem... so thats what ya gotta do -_- it sux i know.
Platinum.Skillz's Avatar
Mine does the exact same thing... Would love to know how to fix it.
Old Oct 24, 2007 | 01:25 PM
drewb16a's Avatar
Default Re: idle high (Platinum.Skillz)
i have a bearly new clutch in there...can i just change the thow out bearing
Old Oct 24, 2007 | 01:38 PM
drewb16a's Avatar
i have a new clutch in there can i just change the bearing
Old Oct 24, 2007 | 01:48 PM
BryanM.'s Avatar
Resident Gearhead
You can just replace the TO bearing.
Old Oct 24, 2007 | 02:02 PM
drewb16a's Avatar
Default Re: idle high (mcvtec)
thanks for the help....ill let you guys know how it turns out
ss65chvlle
May 24, 2008 03:45 PM
C_R_X_V_T_E_C
Jul 15, 2006 09:38 AM
Stoich EG2
Mar 21, 2005 05:53 AM
BlueTeg
Jul 24, 2004 09:24 PM
upstate
Jul 24, 2004 06:10 PM
