Design Review. Please give me your input!!
Here is the latest version of my brace.
I have some decisions to make about the design. The one I am strugelling on the most is just studding the swaybar mount holes, and mounting the swaybar directly to the brace, and eliminating the subframe. Or including the subframe in the swaybar mount.
Here is the question. To bolt the swaybar directly to the Brace, or sandwich the subframe, by bolting the swaybar to a bracket on the backside.
Pro's of no rear bracket:
Easy installation.
Less parts to produce.
Holes could posibly be studed for sway bar mounting.
Eliminates any contact of swaybar with rear-subframe.
Pros of rear bracket:
Stronger mount.
Let me know your input!
Modified by EG-Honda at 10:36 AM 11/7/2007
As is, you're only bolted to the LCA mounts. That allows the plate to flex and only braces the subframe a little bit. Two points of contact.
If you drill through the plate and use longer bolts for the sway bar, the subframe is braced, the plate has even less chance of flexing, and you have a much sturdier structure in general.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">boo for both of those companies charging 200 bucks for a slab of metal.</TD></TR></TABLE>
You get a big chunk of aluminum and have it CNC machined and milled and DIY for less than what ASR charges.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92nahatch »</TD></TR><TR><TD CLASS="quote">make me one ill buy it !!!!</TD></TR></TABLE>
PM me !
PM me !
b16_madman
Jan 9, 2007 01:21 PM
