Intake Manifold
B18C motor with the stock intake manifold with an Iceman Cold Air Intake. I was wonderin' if i were to get the Skunk2 manifold...would my cold air piping still work or would i need to customize/replace my intake piping??
For a Skunk2, blox, aeb, type r style IM, the throttle body will be higher than the stock IM, so your intake pipe will be really close to the hood, my AEM V2 intake actually hits my hood when i close it. I think a type r or an LS intake fits better if you do the skunk2 im swap. What else are you doing to the car, cams, TB, header, etc?
Just Some Advise:
If you do get the Blox IM. while your at it get their throttle body. it has the mounts so you dont have to spend more money on buying a throttle cable from an LS.
They have different throttle bore's you can choose from. I went with the 70mm. and power gains are noticeable! I got my combination for something around $380.
Works great!
Works great!
Well ive already got greddy sp exhaust, dc headers,itr cams, and iceman cold air intake....just basics for now...i still wanta new clutch/flywheel, intake manifold, and am undecided about an ecu chip....
If you do get the IM, you really should get a tune, don't just buy a "custom chip". Also, if you use your stock TB on the IM the clutch cable bracket will also hit the hood, that's why i had gotton the skunk2 IM and and Edelbrock type r style TB and an OEM type r throttle calbe and bracket. Im actually selling the IM/TB and cable/bracket combo cause i decided to go back to stock and sell my gsr.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnDy327 »</TD></TR><TR><TD CLASS="quote">Just Some Advise:
Works great!
BS....... u can use your stock GSR throttle cable.. power gains are not noticeable without bigger camshafts.
Works great!
</TD></TR></TABLE>BS....... u can use your stock GSR throttle cable.. power gains are not noticeable without bigger camshafts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by martyball619 »</TD></TR><TR><TD CLASS="quote">
BS....... u can use your stock GSR throttle cable.. power gains are not noticeable without bigger camshafts.</TD></TR></TABLE>
when you say "bigger cams" you're talkin about like stage 3 cams rite??? not just itr cams rite....
Leon19k
Apr 12, 2017 08:05 AM
