1992 rs stock wont start
Old Oct 24, 2007 | 09:57 AM
sneakerfern's Avatar
Default 1992 rs stock wont start
what up world! i just picked up a 1992 teg rs.. i was driving it the other day and it turned off... and hasnt started since.. i replaced the main relay and distributor but still wont start!!! help please!!!!!! my buddy was looking at he said that there is no spark the fuel pump is good but will not work when the ignition key is set to on position!!!! he also mentioned no power to the injectors please help!!!!!!!!!!!!!!!!!!!!!!
Old Oct 24, 2007 | 12:51 PM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
Default Re: 1992 rs stock wont start (sneakerfern)
Is your battery dead? Have you tried to jump start it yet?
Old Oct 24, 2007 | 12:55 PM
it cranks but wont start battery is fine.. im thinking ecu???
Old Oct 24, 2007 | 01:21 PM
St Jimmy's Avatar
* B A N N E D *
Default Re: (sneakerfern)
if your not getting spark check your ignitor and coil and make sure your cap and rotor are in good condition.
Old Oct 24, 2007 | 01:48 PM
Schister66's Avatar
Man U FTW
Check and then double-check the timing belt. I had a starting problem last winter that confused the hell out of me. After going through every problem i could think of, i reluctantly brought it to a Honda dealership. They went over everything and eventually found that my timing belt had shredded and the crank pulley had skipped 4 teeth. It would give all the signs that it would start, but never started. I had fuel, spark and obviously had air.
Check that because shredded timing belts can be a big damn headache. Also, mine quit on me during low rpm slow driving.
Old Oct 24, 2007 | 06:24 PM
weavertime1's Avatar
Default Re: (Schister66)
Check the ecu fuse!!! It is located under the passenger side under hood fuse panel!!!
Old Oct 29, 2007 | 01:01 PM
Default Re: (weavertime1)
it was the ecu.. fires right up now
Old Oct 29, 2007 | 06:01 PM
Good Deal!!!
cscteardrop86
Jun 17, 2016 12:04 PM
93accordmike
Nov 2, 2008 07:23 PM
djtsmith007
Aug 20, 2007 08:57 PM
trix are for kids
Aug 17, 2007 10:40 PM
G a b e
Dec 14, 2002 09:29 PM
