90 GT 10SEC CAR STREETABLE VIDS for sale or trade
Old Oct 24, 2007 | 09:56 AM
cbr900rr_uponone's Avatar
Default 90 GT 10SEC CAR STREETABLE VIDS for sale or trade
I figured some ppl would be like me on here and would like domestics just as much as imports well here it is, mainly want to sell fast thats why the price is so low but might consider trading for a boosted honda or a bike.....located in wisconsin
Unfortunatly something has came up and i have to sell my car, i have no room for it anymore because i dont have a storage unit or a place to park it so my loss is definatly your gain! This car has twice the money in parts in it then what i am asking for....Its a 90 Gt. Black with black and gray interior...This cas has almost everything done to it and its a beast! Here is a list of everything that is done to it and the little things that are bad about the car....
Exterior-
*4" cowl hood
*pro stars with m/t front runners and m/t 28" slicks (i also have a set of 26" drag radials that i can add with the car)
*clear headlights, side markers, and fog lights
*battery cut off switch in the liscense plate
*tinted windows all around
Interior-
*10pt cage in black (its an eight now because i drive it alot but i have the 2 bars to go with it)
*gray 4cyl seats not very nice, but also have a set of black plastic racing seats with black seat covers that can go with the car
*custom gauges no speedo or gas but the fuel pressure gauge helps with gas.
autometer oil pressure, water, cyl heads, tac with shift light on roof, 2 fuel pressure gauges both in hood 1 for motor other for nitrous, nitrous gauge
*no back seats, all black interior
*battery in the hatch with moroso box and battery cut off switch in liscense plate
*3 switches in dash, 1 for fuel pump, 2nd for fan/alt, and 3rd for nitrous
*msd with 2 step and timing retard for the nitrous
*nitrous button and 2 step button in the steering wheel
*nitrous bottle behind driver seat
*no heat or stereo, but you can always put them back in
*p/w p/l no p/s though
Suspension-
*4:30 gear
*trick flow pumpkin cover
*strange 33 spline axels, spool with c clip eliminators
*5 lug swap with chevy pattern
*granetelli uppers and weight jack lowers
*moroso trick springs with air bag in the back
*tubular d&d k member upr tube arms coilover kit
*moroso driveshaft w/ safety loop
Motor/Tranny
*fully balanced dss pro bullit 306
*11:1 compression
*high volume pump canton pan
*dss main girdle (block was undercut .010 for the compression)
*fluidampener balancer
*canfield 54cc heads
*2.02 1.60 valve springs
*anderson m71 cam
*clowes double roller chain
*hardened pushrods
*dss 1.6 rockers (sheet metal valve covers, look clean and good)
*victor jr intake
*holley 750 carb
*msd pro bullit distributor
*hvc coil
*digital 6 box with retard and 2 step
*2 holley blue fuel pumps (1 for motor -8 feed line and fram filter and 1 for spray 3/8 feed line and fram filter stock tank sumped)
*bbk longtubes, summit custom x pipe into dynomax race mufflers into turn downs
*nos plate kit with the big solenoids (needs nitrous line from bottle to carb...(never sprayed on the 5spd)
*Tremec trans (with less then 400 miles on it)
*spec stage 3 clutch
*pro 5.0 shifter
less than 10 spray passes on this setup with the auto last year this year the car has about less then 400 miles on the new trans and clutch. the car went 11.90 on motor with a big intake and carb. stepped down the carb put an unported victor jr on the car with a 750holley and did the new cap and rotor and a set of moroso ultra 40 plug wires and the car really rips on the street...the car could use a paint job its not the greatest, has some rust on the passenger fender, and scratches on the hood etc. car has no heat or stero but these cars are easy to put them back in. for the interior it just needs the speaker covers and the stereo put back in with some better seats and it would be complete....for what im asking for the car its worth twice it just in parts! but i needs to sell....the car should go 10's on spray with a good driver but i dont know....i will have videos and more pics tomorrow....car fire's up everytime and is a blast to drive, gets tons and tons of compliments every time i start it up til i turn it off and put it away lol
LOOKING FOR $7000 THE CAR IS WORTH THAT IN PARTS!!!
http://vids.myspace.com/index.cfm?fu...eoid=27829 79
http://www.youtube.com/watch?v=451S3EDMlco
http://www.youtube.com/watch?v=dFFU1eP5Yg8
Old Oct 24, 2007 | 02:37 PM
http://vids.myspace.com/index....82979
video of the car at the track when it was an auto, no spray and differnt carb.....car is completly streetable i drive it almost everyday everywhere!
Old Oct 24, 2007 | 03:33 PM
zhan28's Avatar
lol, that's pretty sick. bump for you.
Old Oct 25, 2007 | 04:54 AM
thanks ttt
Old Oct 25, 2007 | 09:49 AM
lunch time bump!
Old Oct 26, 2007 | 07:24 AM
to the top
Old Oct 31, 2007 | 07:08 AM
ttt
cbr900rr_uponone
Oct 31, 2007 07:09 AM
