right turn knocking noise
Old Oct 24, 2007 | 08:51 AM
219DAdriver's Avatar
Default right turn knocking noise
so when i make right hand turns im hearing a knockin noise. im not sure if its my axle or wut but i wus wondering if anybody is havin the sae problem and may kno wut it is???
Old Oct 24, 2007 | 08:57 AM
hatchling37's Avatar
Default Re: right turn knocking noise (219DAdriver)
Hey, go to the Geek Squad because your spell check is broken. Get underneath that sumbitch and look to see if one of your boots is torn open. You can tell really easily, because you'll probably have axle grease slung all the expletive over everything in there. If they're fine, jack the car up and shake the wheel side to side. Hear or feel the clunking? Something with your steering. If nothing, shake the wheel up and down. Loose? Wheel bearing. If all that checks out, pull your wheel off and check your suspension for loose bolts and look in around your brake rotor. Maybe you have a little chunk of gravel or something in there.
Old Oct 24, 2007 | 09:49 AM
AWD Terror's Avatar
Default Re: right turn knocking noise (hatchling37)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 &raquo;</TD></TR><TR><TD CLASS="quote">Hey, go to the Geek Squad because your spell check is broken. Get underneath that sumbitch and look to see if one of your boots is torn open. You can tell really easily, because you'll probably have axle grease slung all the expletive over everything in there. If they're fine, jack the car up and shake the wheel side to side. Hear or feel the clunking? Something with your steering. If nothing, shake the wheel up and down. Loose? Wheel bearing. If all that checks out, pull your wheel off and check your suspension for loose bolts and look in around your brake rotor. Maybe you have a little chunk of gravel or something in there.</TD></TR></TABLE>
You make fun of him for spelling, yet you have no paragraphs.
Check your CV joint first. Easiest way to check is to look and see if the boot is ripped.
Check your tie rods by shaking the wheel left to right.
Check the ball joint by getting a breaker bar under the tire and lift up.
Old Oct 24, 2007 | 09:50 AM
boostedh22lude1's Avatar
your axle is busted
Old Oct 24, 2007 | 09:58 AM
AWD Terror's Avatar
Default Re: right turn knocking noise (boostedh22lude1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedh22lude1 &raquo;</TD></TR><TR><TD CLASS="quote">your axle is busted</TD></TR></TABLE>
Probably not. The axle itself does not normally break. The joints are what goes bad. They normally last about 500 miles or so after they start to click.
Old Oct 24, 2007 | 10:04 AM
Default Re: right turn knocking noise (AWD Terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>Easy, there, English major. There's no real need for me to break up what I told him into different paragraphs. And thanks for the Cliff's notes on my reply for those that can't stand reading my HUGE paragraph.
Old Oct 24, 2007 | 10:12 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 &raquo;</TD></TR><TR><TD CLASS="quote">Easy, there, English major. There's no real need for me to break up what I told him into different paragraphs.</TD></TR></TABLE>
Easy there killer. You were the one talking like an english major.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 &raquo;</TD></TR><TR><TD CLASS="quote">Hey, go to the Geek Squad because your spell check is broken.</TD></TR></TABLE>
And I didn't think I wrote cliff notes b/c I didn't read after the first sentence.
Old Oct 24, 2007 | 10:17 AM
dizzzane's Avatar
AWD Terror is right, it isn't you axle you may be hearing, its the CV, check to see if the boot is torn on the driver said (since you said when you turn right). A bad CV should be a clicking, not a knocking. A knocking is more likely to be a wheel bearing. With the car on jack stands, wiggle the tire by holding at the 12 o'clock and 6 o'clock positions on the tire. If it feels loose, most likely a wheel bearing.
Old Oct 24, 2007 | 10:26 AM
And I didn't think I wrote cliff notes b/c I didn't read after the first sentence. </TD></TR></TABLE>Just flippin' you ****
Old Oct 24, 2007 | 10:43 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 &raquo;</TD></TR><TR><TD CLASS="quote">Just flippin' you **** </TD></TR></TABLE>
Ok. I'm not sure if that's a good thing or a bad thing, so...yea.
Sorcin
Oct 18, 2010 08:21 PM
Sorcin
Suspension & Brakes
May 19, 2010 05:16 PM
1_slow_crx
Sep 10, 2006 08:29 PM
SOHCVTECx2
Oct 16, 2004 10:58 AM
Carbcivic
May 28, 2004 02:13 PM
