1992 honda accord
the d4 light stays lit even in reverse park it makes no diference. i tried jumping the wires behind kick panel on pass side the only thing . i got was the check engine light lit up . what might this be
Are you having any shifting or anyother sort of problems with your tranny to go along with this solid D4? A solid light usually indicates a problem in the TCU (Transmission Control Unit).
yes it starts off in i think it is 3rd gear . i can pull the shifter down to 1st an it will go to first but when i shift up it goes in what i think is 3rd gear . as soon as the d4 light goes out everything works fine again untill that light lites up
BamaBleach
Oct 10, 2022 05:36 PM
Hondafreak2006
Sep 17, 2006 07:33 PM
Ralphalot
Apr 21, 2006 05:10 AM
