Tein Flex Problem...........
I have a type r and a friend of mine gave me his suspension which came off his gsr i think the front shocks can work but the back wont cause of the fork however i noticed that the lower bracket can be screwed off is there a way i can buy the lower bracket from tein that fit the type r setup or is it easier to just get some skunk LCA's and use it the way they are...........??? please help
da hell, seriously? The couldn't sell you the lower eye bushing used with ITR LCA's? I thought that was the whole point of making that bottom piece threaded like that.
to Tein USA
to Tein USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">da hell, seriously? The couldn't sell you the lower eye bushing used with ITR LCA's? I thought that was the whole point of making that bottom piece threaded like that.
to Tein USA</TD></TR></TABLE>
What's the difference? He has to spend money either way - buy lower mounting fittings, or buy cast beam-style rear lower control arms.
The reason the bottom piece is threaded is because the ride height adjustment is separate from the spring preload adjustment since the damper has a fixed stroke length.
to Tein USA</TD></TR></TABLE>What's the difference? He has to spend money either way - buy lower mounting fittings, or buy cast beam-style rear lower control arms.
Thanks
