smoked peice of plastic temp.gas cluster/tv inside dash
Old Oct 23, 2007 | 11:45 PM
LaEzEnT's Avatar
Default smoked peice of plastic temp.gas cluster/tv inside dash
Hello, I'm going to install a tv screen behind the dashboard in the center and i would like to know
how to remove or cut the black plastic off of the back of the smoked peice of plastic.
Basically i need to seperate the smoked plastic from the black plastic part
Also, how do you relocate the temp/gas gauge to the far right passenger side and what do you do about the clock adjustment stick
If there are pictures that would be really helpful
thank you
Old Oct 24, 2007 | 12:08 AM
Hawkze_2.3's Avatar
Default Re: smoked peice of plastic temp.gas cluster/tv inside dash (LaEzEnT)
Enjoy: https://honda-tech.com/zerothread?id=1660983
The black plastic does not come off, you will have to very carefully cut out the part where you want your TV to go. VERY carefully
Old Oct 24, 2007 | 12:32 AM
LaEzEnT's Avatar
Default Re: smoked peice of plastic temp.gas cluster/tv inside dash (Hawkze_2.3)
thanx, i was actually looking for your thread but i didnt know what was the key for the search button so it kept giving the result i didnt want.
Also, how would you recommend when cutting the black plastic piece without scratching the smoke cover and how did you make the mount/support for the left side of the temp/gas gauge?.
Old Oct 24, 2007 | 02:26 AM
BlackCatt's Avatar
Just checked out the thread, bloody nice dash setup.
Old Oct 24, 2007 | 08:24 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LaEzEnT &raquo;</TD></TR><TR><TD CLASS="quote">
Also, how would you recommend when cutting the black plastic piece without scratching the smoke cover and how did you make the mount/support for the left side of the temp/gas gauge?. </TD></TR></TABLE>
Slide something thin between the glass and black plastic like cardboard or plastic so if you go too far it won't knick the glass. The mount for the left side was just a peice cut from the big white peice...there should be a pic of what I cut at the top of th first page.
threesixes
Jan 8, 2007 09:50 AM
JayDeEM-ike
Feb 3, 2005 09:39 PM
rossockr
Apr 11, 2003 02:54 PM
A D NOH
Mar 6, 2003 07:23 AM
