95 LS need help determining if rack or ps pump is done?
Old Oct 23, 2007 | 09:29 PM
h23vtecDA's Avatar
Default 95 LS need help determining if rack or ps pump is done?
when i drive the car the steering is very tight and hard to steer with one hand.
also when im driving i hear a loud whining sound coming from the engine like a belt is too tight or a pulley is fucked? could the pump not be circulating the fluid or would the rack be toast?? thanks for the input
Old Oct 24, 2007 | 05:30 AM
weavertime1's Avatar
Default Re: 95 LS need help determining if rack or ps pump is done? (h23vtecDA)
Did you check the powersteering fluid level. PS cars whine annoyingly when they are low on fluid. If it is full and the belt is still there it is either your pump is bad, or the rack is bad. Good luck!!!
wallendiaz
Nov 23, 2012 06:02 AM
itr1235
Jun 13, 2011 07:15 AM
cityofcaterpillars
Apr 27, 2010 11:49 AM
ktwanky
Oct 30, 2006 05:13 PM
Furry in your eye
May 30, 2003 08:13 PM
