Jack points on the car
Is there a jack point at the front center of the car?
I want to jack up the front lifting both sides up so I can change my oil.
Naturally I would put jack stands on the side after I raise the car.
TIA
4th gen cb7
TIA
4th gen cb7
Shouldn't but I dont believe that's a legit jack point, that's the tow hook.
There's the 4 on the sides and use jack stands
*edit*
<-- owned
Accord FAQ - Jack Points under Misc
http://syclone.motocrew.com/CG5/jackpoints.htm
there is a jack point in the front at least for CG's
I guess it's the same for CD's
*edit*
<-- owned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan »</TD></TR><TR><TD CLASS="quote"><-- owned
I guess it's the same for CD's</TD></TR></TABLE>
haha, glad you found it because I was just about to direct you there
yes, even in the HELM manual that is listed as a jacking point.
I always lifted my 95 EX from there.
If you look under the car, it located on the center beam of the front subframe, you'll know it when you see it.
mckeand13
Mar 3, 2007 03:14 PM
99delsol
24
Oct 20, 2006 11:00 AM
