2 dumb swap questions...
Use the forums to your advantage. Use the big red search key at the top right of the webpage and use the FAQ to your advantage. There is a whole bunch of stuff on OBD0 B16 swaps in there.
http://www.norcalcrx.org/dropp...p.htm
https://honda-tech.com/zerothread?id=131949
There are a couple to start you off. I recovered those from the FAQ, it's not hard you jusut have to search.
bump, read the 2 links. not much help...I did see that i can use my oem clutch cable; i just have to mod it to get it to fit. Just am confused on what timing mount i need. I have the hasport mounts for it already just don't know if i need a stock si one, b16, or da b18.
user 72830283
40
Sep 22, 2005 12:06 PM
crxh22project
11
Jan 27, 2005 08:29 PM
