vtec not pulling very strong
Old Oct 23, 2007 | 04:24 PM
hondapimpin420's Avatar
Default vtec not pulling very strong
was wondering if yall could throw some senarios at me so maybe i could figure out why. the pressure switch and solinoid are both good. does oil type have anything to do with it. and when is it suposed to kick in. im pretty sure it kicks in but i think its just not very strong.
Old Oct 23, 2007 | 04:27 PM
instrument's Avatar
oh man
you're in for it now.
Old Oct 23, 2007 | 04:28 PM
B16B_coupe's Avatar
HRD PKR
Default Re: vtec not pulling very strong (hondapimpin420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondapimpin420 &raquo;</TD></TR><TR><TD CLASS="quote">was wondering if yall could throw some senarios at me so maybe i could figure out why. the pressure switch and solinoid are both good. does oil type have anything to do with it. and when is it suposed to kick in. im pretty sure it kicks in but i think its just not very strong. </TD></TR></TABLE>
what car, motor do you have. not all honda's have vtec
Old Oct 23, 2007 | 04:55 PM
Default Re: vtec not pulling very strong (B16B_coupe)
ahah man i aint in for ****, was jus tryin to find HELP. but i seached like hell and found a trouble tree
https://honda-tech.com/zerothread/1812135
thats that pimp **** right there buddy. but it is a vtec and its a d16. but i cant here it kick in or anything. i reckon ill figure it out, but if you have any helpful hints then im all ears.
Old Oct 23, 2007 | 04:57 PM
devney's Avatar
You aren't going to "feel" vtec in a d16.
Old Oct 23, 2007 | 04:59 PM
mustang5.slow's Avatar
* B A N N E D *
you're not in for anything it's HT. It's a home for all Honda owners and such to ask Q's. hope you figure it out. but you cant really expect much from a d series if it's stock.
the guy above is right but you damn sure will hear it. when i had a single cam i was happy with just with the recognition of vtec popping.
Modified by mustang5.slow at 7:18 PM 10/23/2007
Old Oct 23, 2007 | 05:06 PM
LS-V_T_fullrace_EG's Avatar
Default Re: vtec not pulling very strong (mustang5.slow)
throwin in my $.02... check your oil level... low oil = bad vtec or too low = no vtec
crazyguy's Avatar
Default Re: (devney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devney &raquo;</TD></TR><TR><TD CLASS="quote">You aren't going to "feel" vtec in a d16. </TD></TR></TABLE>
thats true..and u will hardly "feel" any etec on b16 either
Old Oct 23, 2007 | 05:14 PM
B16B_coupe's Avatar
HRD PKR
Default Re: (crazyguy)
yeah you will be very lucky to hear vtec on a stock sohc, but just in case check your oil level
Old Oct 23, 2007 | 05:31 PM
Default Re: (B16B_coupe)
thanks peoples, im sure i will be able to figure it out, but by the way its got skunk 2 cam, valve, springs, and 11:1 comp pistons, decked and head shaved, and some other small stuff. just tryin to squeze all i can out of the little thing. but iheard it should atleast be heard.
do you think a 60 or 62 mm TB would benifit me in my situation???
Old Oct 23, 2007 | 05:51 PM
v8 integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">
thats true..and u will hardly "feel" any etec on b16 either</TD></TR></TABLE>
psh!! i feel my b16's vtec...it gives me whip lash!! well not whip lash..but i feel it pull
Old Oct 23, 2007 | 05:53 PM
devney's Avatar
Yeah in a b series it will be louder and pull harder but you're still not going to really "feel" it. And in a d series, most definitely not going to feel it pull any harder. Anyways this has been covered many times so I don't want to start a discussion.
Old Oct 23, 2007 | 05:54 PM
skcivic4life's Avatar
Default Re: (v8 integra)
if anything i could hear vtec kick in not really feel it with my d series motor.
Old Oct 23, 2007 | 06:02 PM
jdmjohnyyy's Avatar
Default Re: (skcivic4life)
try changing you oil
Old Oct 23, 2007 | 06:12 PM
v8 integra's Avatar
Default Re: (jdmjohnyyy)
use synthetic vtec oil jk.. my opinion is to put some modifications on that...i herd turbo's go pretty good with d16's...
Old Oct 23, 2007 | 06:19 PM
ddd4114's Avatar
Default Re: (hondapimpin420)
You should not be able to feel the crossover. If you can, then you need a tune. You also can really only hear it with some sort of free flowing intake. If you're not throwing any CEL's, you probably have nothing to worry about.
Keep in mind that the following prerequisites must be met for VTEC to engage:
1) engine speed must be sufficient
2) engine temperature must be sufficient (fully warmed up engine)
3) throttle position must be sufficient
4) vehicle speed must be sufficient (I think it's ~20mph)
5) oil pressure must be sufficient (try changing your oil and filter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondapimpin420 &raquo;</TD></TR><TR><TD CLASS="quote"> do you think a 60 or 62 mm TB would benefit me in my situation???</TD></TR></TABLE>
A 58mm might. 60mm+ on almost all N/A d-series builds is overkill. Call Skunk2 and see what they recommend.
Old Oct 23, 2007 | 06:23 PM
SoullessJapaneseMachine's Avatar
Default Re: (ddd4114)
u probably need a new vtec sensor.....
Old Oct 23, 2007 | 06:31 PM
92sihbk's Avatar
Default Re: (SoullessJapaneseMachine)
you deff wont feel it, although, with your setup you SHOULD hear it, as long as everything is functional. My friends D16 with 12:1 compression and stg 2 cam is veery loud. Check for error codes, thats where you should be starting.
Old Oct 23, 2007 | 06:44 PM
MeetyourconnecT's Avatar
It is a single slam after all, I asume your running with the p08 brain?
Old Oct 23, 2007 | 06:55 PM
ShortyzKustomz's Avatar
I have a z6 in mine and you really dont feel or hear it, maybe a slight difference in pull but after 5 grand its not a hige difference
ddd4114's Avatar
Default Re: vtec not pulling very strong (MeetyourconnecT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeetyourconnecT &raquo;</TD></TR><TR><TD CLASS="quote">I asume your running with the p08 brain?</TD></TR></TABLE>
It's a d16. Why would you assume that?
Old Oct 23, 2007 | 06:56 PM
k20jdm's Avatar
Hi well i have d16y8 with mild bolt on's an I hear my vTec everyday cause I hit it every day an mine is loud...oh an I can feel just a lil when it dos crossover but not that much to really tell.
Old Oct 23, 2007 | 06:57 PM
Johnny Ricer's Avatar
Default Re: vtec not pulling very strong (ddd4114)
You need to change your vtec oil....
Oh and the vtec flux compacitor it should work than...
96 EX's Avatar
On a d16 you will barely feel or hear vtec unless you have exhaust and maybe a CAI and when you do hit vtec it should be around 5500 rpms I believe.
Old Oct 23, 2007 | 06:58 PM
Default Re: vtec not pulling very strong (soundpsych)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20jdm &raquo;</TD></TR><TR><TD CLASS="quote">Hi well i have d16y8 with mild bolt on's an I hear my vTec everyday cause I hit it every day an mine is loud...oh an I can feel just a lil when it dos crossover but not that much to really tell. </TD></TR></TABLE>
Haha works well with my quote in my sig
And I have header full exhaust and intake and still dont "Hear it"
