looking for some people with auto SS >> 5spd 5th gen swap in portland area
Old Oct 23, 2007 | 03:29 PM
alpinefr3ak's Avatar
Default looking for some people with auto SS >> 5spd 5th gen swap in portland area
Well my auto ss tranny finally went out, now I'm gonna do the 5spd swap but I'm looking for someone around portland area that has done it before so me and my mechanic aren't going into this thing cold turkey.
also any tips/pointers would be nice and if you have some parts that would also be awesome, stuff I need is:
Trans mounts-side
Engine Mount-rear (rear is optional-the rear auto mount will work)
Flywheel and bolts
Clutch Kit and bolts
Clutch Master Cylinder
*Clutch Slave Cylinder
*Clutch Dampener
*Vehicle Speed Sensor (VSS)
*Reverse Switch
*Hydrolic Lines
*5spd Starter
Clutch Pedal Assembly
Brake Pedal Assembly
Shifter Assembly
Shift linkage
5speed ECU
5spd Intermediate shaft (half-shaft)
5spd Gauge Cluster (optional)
(I copy/pasted that info off of http://www.mazmo.com/zameoj/swap.htm) so credit to them
I think im going to be buying a 4th gen m2a4 tranny with a quaife LSD, what ECU do I need to make that work with my 5th gen?
My car is 98 base model fyi
Old Oct 23, 2007 | 03:49 PM
mafia's Avatar
Default Re: looking for some people with auto SS >> 5spd 5th gen swap in portland area (alpinefr3ak)
Ill be in that area in about 2-3 weeks, I can help you with the swap If you want. I did this on my lude.
Old Dec 11, 2007 | 06:56 AM
mikemjohnson's Avatar
Default Re: looking for some people with auto SS >> 5spd 5th gen swap in portland area (mafia)
which helms manual do i need, i dont see one concerning transmission
http://www.helminc.com/helm/re...PCMFA
thanks
Old Dec 11, 2007 | 07:03 AM
mgags7's Avatar
You want the entire factory manual, it has a transmission section.
Alude99
Sep 25, 2007 05:04 PM
DC2-JRSC'd
Jan 12, 2007 02:05 PM
lvblkjack
Oct 18, 2005 07:14 PM
blackssvtex
Jul 6, 2003 01:39 AM
