1000cc injectors flowing at ~900cc?
Old Oct 23, 2007 | 03:22 PM
champLSinteg's Avatar
Default 1000cc injectors flowing at ~900cc?
I just got my injector flow test results from Rich @ cruzinperformance.com, great guy by the way, and they flow ~900cc! These are suppose to be 1000cc precision injectors but they flow less than that. Good thing is that they are pretty close to each other. I looked up the part number on the injectors and they are 1000cc.
When i tune should I input these as 900cc injectors? or keep them as 1000cc?
here are the results...
Old Oct 23, 2007 | 06:57 PM
wHOAlly's Avatar
Default Re: 1000cc injectors flowing at ~900cc? (champLSinteg)
what are you tuning with?
when you "input" the injectors, in most cases, all it does is scale all your fueling up/down by watever % change of stock vs watever u put in. so if they flow 900cc, id put in 900cc
Old Oct 23, 2007 | 07:30 PM
im tuning on crome. I had a hard time idleing them maybe thats why.
Old Oct 23, 2007 | 10:01 PM
wHOAlly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by champLSinteg &raquo;</TD></TR><TR><TD CLASS="quote">im tuning on crome. I had a hard time idleing them maybe thats why.</TD></TR></TABLE>
big injectors are always harder to tune the idle, imagine trying to water a small plant with a fire hose
Old Oct 24, 2007 | 04:22 AM
mmuller's Avatar
Mad Scientist
have you messed with injector battery offsets and the main offset multiplier?
Old Oct 24, 2007 | 07:49 AM
Default Re: 1000cc injectors flowing at ~900cc? (mmuller)
I set the injector battery to the 1000's and played with the multiplier but it would run very lean or very rich with only 1% change in fuel. WOT was fine though.
Old Oct 25, 2007 | 06:02 AM
mtber's Avatar
No its not why.
Try another ems & you will see idling 1000cc injectors won't be such a task as it is with crome.
Old Oct 25, 2007 | 07:02 AM
Default Re: 1000cc injectors flowing at ~900cc? (mtber)
I just picked up an s200. Should I still imput them as 1000's though?
Old Oct 25, 2007 | 09:37 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by champLSinteg &raquo;</TD></TR><TR><TD CLASS="quote">I just picked up an s200. Should I still imput them as 1000's though?</TD></TR></TABLE>
Yes, you will be fine.
Old Oct 26, 2007 | 05:55 AM
Dogginator's Avatar
Daisy... Daisy...
What was the fuel pressure during the test? If it was the same as the fuel pressure on your car, then used the measured flowrate.
Old Oct 26, 2007 | 07:02 AM
Default Re: 1000cc injectors flowing at ~900cc? (Dogginator)
they were tested at 43.5 psi. I am running at 55psi.
tegman2
Aug 9, 2008 05:18 PM
champLSinteg
Oct 24, 2007 07:44 AM
rice a roni
May 20, 2006 02:32 AM
gsrhb7
Feb 3, 2005 08:46 PM
Vtec92Civic
Mar 11, 2004 08:17 AM
