intake manifold question on crx
Old Oct 23, 2007 | 01:45 PM
sins's Avatar
Default intake manifold question on crx
Can someone out there give me the specs or guide me thru it step by step on whats all needed to swap out the regular intake manifold on a crx sohc engine to a z6 manifold if you have pics to show that would be of great help.....
Old Oct 23, 2007 | 02:06 PM
jdm_titan's Avatar
Default Re: intake manifold question on crx (sins)
SEARCH BUTTON, that is the path way to wisdom.
Old Oct 23, 2007 | 02:11 PM
sins's Avatar
Default Re: intake manifold question on crx (jdm_titan)
dont get it
Old Jan 14, 2008 | 02:27 PM
Rease3's Avatar
i searched and there is nothing on it about swapping a z6 mani
Old Jan 20, 2008 | 10:10 AM
zombieD's Avatar
Default Re: intake manifold question on crx (Rease3)
you will need a throtle cable from the 92-95 Civic EX for the Z6 throtle body. and you can choose to rewire your map sensor if you would like. just lenghthen the wires from the old map sensor to the one on top of the Z6's manifold. you can re use the injectors from your CRX or you can use the Z6's too. just remove your resistor box. it wont make any hp difference though but if you do want the obd1 injectors anyway you will need the injector clips and replace them with your obd0 clips because the injectors use diffrent clips. but as for me just keep the origional injectors its a lot easyer and cheeper to stick with those. its also be best if you got a new intake manifold gasket. now im not sure if this is all that is needed to completely do the swap since i am also having trouble hooking up my Z6 manifold, but its a start. good luck!
i was wondering if you couled help me with my problem. i was wondering if you had any pictures on how your original CRX manifold is hooked up if its the D16A6 (Si) motor because im having trouble conecting all the right sensors with the correct plugs on my swap. i also posted a topic "HELP - CRX Si with Z6 swap - how to corectly hook up Z6 intake manifold?" just search for it if you have any answers.
teg4thewin
May 28, 2010 05:45 PM
92integracer
Nov 7, 2008 03:17 PM
si0385.
Jan 7, 2006 10:11 AM
IamVtec
May 7, 2003 02:26 PM
crx_91si
May 16, 2002 11:41 AM
