obd0 b18a questions
i've got a b18a obd0 longblock that needs a new head. i have a 97 ls head. i've got obd1 b18a and obd0 intake manifolds. the car is a 90-91 DA.
if i were to use the obd0 manifold, i could stay obd0? i'm on a tight budget, is it worth it to go w/ a obd1 conversion?
thx!
thx!
if your going turbo or going to need tunning down the road obd1 would be a good idea. If your just going to stay stock with boltons obd0 is fine. You just to to switch over your obd0 distributor and intake manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy »</TD></TR><TR><TD CLASS="quote">if your going turbo or going to need tunning down the road obd1 would be a good idea. If your just going to stay stock with boltons obd0 is fine. You just to to switch over your obd0 distributor and intake manifold.</TD></TR></TABLE>
awesome, thx
also, aside from sensors, any major differences b/w obd1 & obd0 im's?
awesome, thx
OBD0 fuel injectors need a resistor box thats already in your car so you will need to make sure you use the obd0 injectors, other than that its pretty much the same.
nycpatron
Mar 29, 2010 09:52 PM
civicracer94
Dec 8, 2006 01:28 AM
