EP3/RSX rotors vs. RSX-S Rotor Diameters
I did a search and couldn't find anything so I thought I would look all the specs up and put a list together.
Front Rotor Sizes
02-03 EP3 (4 lug): 262mm, 10.3"
04-05 EP3 (5 lug): 262mm, 10.3"
02-06 RSX-S: 300mm, 11.8"
02-06 RSX base: 262mm, 10.3"
Rear Rotor Sizes
02-03 EP3 (4 lug): 260mm, 10.2"
04-05 EP3 (5 lug): 260mm, 10.2"
02-06 RSX-S: 260mm, 10.2"
02-06 RSX base: 260mm, 10.2"
If anyone finds any errors, let me know.
Front Rotor Sizes
Rear Rotor Sizes
If this is accurate (I have not checked), then it'll make a good FAQ.
If you're felling really frisky, then we should put together what brake pads are interchangable (such as front 99-00 Civic Si = front EP3).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice »</TD></TR><TR><TD CLASS="quote">I did a search and couldn't find anything so I thought I would look all the specs up and put a list together.
Front Rotor Sizes
Rear Rotor Sizes
If anyone finds any errors, let me know.</TD></TR></TABLE>
Good info.....
Front Rotor Sizes
Rear Rotor Sizes
Good info.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice »</TD></TR><TR><TD CLASS="quote">How would you check interchangabilities like that?</TD></TR></TABLE>
Not sure. I just know about the 99-00 Si/Ep3 because the part numbers were the same when I was looking.
