Lighting HID/Xenon kits, Retrofits and Associated Topics
92-95 civic jdm style fog lights not working
Old Oct 23, 2007 | 10:54 AM
lilo_goki's Avatar
Default 92-95 civic jdm style fog lights not working
i just recently install my ebay jdm style foglights and it's not working. i check everything and i did everything correctly but somehow it's not working. there's power to the switch, but when i push the switch button, the foglights won't turn on. anyone had any problem with this before.
Old Oct 23, 2007 | 11:29 AM
lilo_goki's Avatar
bump? could moving the wires that connect to the relay help solve the problem as well. i meant switchin it around.
Old Oct 29, 2007 | 06:44 AM
racehesh's Avatar
Default Re: (lilo_goki)
you have good ground?
Old Oct 29, 2007 | 06:48 AM
Duane_in_Japan's Avatar
Default Re: (racehesh)
So you have a switch, a relay, some wireing and the fog light, which terminals on the relay are for the coil, are for the switch and most importantly, the relay coil, which terminal is positive and which terminal is negative, for the relay switch, which terminal is positive and which terminal is negative.
Did you hot wire the lights to be sure they worked, did they ever work since you have installed them. DO YOU HAVE A TEST LIGHT OR MULTIMETER, get back with us please with all the answers to ALL the questions.
Old Oct 29, 2007 | 12:10 PM
bpr0422's Avatar
Default Re: 92-95 civic jdm style fog lights not working (lilo_goki)
https://honda-tech.com/zerothread/1812043
cheap_noob
May 5, 2012 02:48 PM
sileighty_911
Audio / Security / Video
Jun 19, 2007 01:38 PM
LoveOfMoney
Feb 6, 2007 04:38 PM
TaboR
Nov 30, 2001 07:54 AM
