Best tire pressure for M/T ET Drag Slicks
i just got a set of 22x8x15 MT ET Drag Slicks.
What is the best pressure to run them at?
Anything under 15 psi looks flat..
Somebody help me out.. Thanks
[Modified by GSRTypeR, 5:24 PM 6/21/2002]
I found that 17 PSI worked great for my set-up. I also was trying to promote a little wheelspin off of the line. The slick can be run down to 12 PSI (possibly lower) but the short sidewall will make it look like it is flat. Don't forget that these are "wrinkle wall" slicks.
the problem is that the slicks are 22x8x15... they have less sidewall than small diameter rims.. when i use 10 lbs it almost looks like i'm ruining them..
please help me out.. thanks..
i have the exact same tires. i go no lower then 10lbs on poor condition tracks like palmdale for a little extra bite. at fontana, i runa bout 11lbs, 12 at most.
m/t doesn't sugguest on doing burn out in the water box, so what are you guys doing instead? dry burn out? no burn out??? i'll gona try my type R anyone know what i should rev to or on how i should lanuch?
of course they dont...they want you to rip through as many tires as you can.
Do a wet burnout, at the front edge of the waterbox.
