safe charge for yusa 600rr battery
Old Oct 23, 2007 | 07:34 AM
pouponu's Avatar
Default safe charge for yusa 600rr battery
which is safe to charge 2amp slow charge 35 amp medium charge or 200amp fast charge, are any of these unsafe.....?
pouponu's Avatar
Default ??? safe charge for yusa 600rr battery (pouponu)
also does anyone on here sell the yusa ytz10 or w/e the oem battery for the 600rr is
Old Oct 23, 2007 | 10:45 AM
not2slo128's Avatar
Default Re: safe charge for yusa 600rr battery (pouponu)
200amp charge rate?!?! wow.. didnt know it goes that high... that sounds pretty dangerous... so does 35 amps...
I think 2amps is about as high as you want to go on a 12v battery in the 600rr. I charge mine at ~800mAH
Old Oct 23, 2007 | 10:49 AM
MSchu's Avatar
My Name is Nobody
2 amp for trickle charge over night/hours... the fast charge is a jump start set up... only use it for this
Old Oct 23, 2007 | 04:30 PM
pouponu's Avatar
Default Re: safe charge for yusa 600rr battery (MSchu)
thank you
Old Oct 25, 2007 | 10:03 AM
Rc1honda's Avatar
Yeah go with the 2 amp charge. 35 is way to much. any moe then 2 amp will cuase the battery to sulflate. And the life of the battery will go to nothing. What you should do is go out and buy a product called BatteryTender. It's one of the best investments you can make for you motorcycle. It easy to use and it's safe. It great for long periods of storage or just to keep the battery at max charge. Go to BatteryTender.xom and pick up the BatteryTender plus. Its awesome it costs about 60 bucks which is nothing compared to having to buy a new battery every year. Remeber when a battery goes completly dead you can never bring it back to full charge, if you have a yusa sealed one the is. also if you overcharge a battery it will start to sulflate and it won't lsat nearly as long as it' s supposed to. The BatteryTender charges the battery fully and then keeps the charge at a float charge so it senses when it starts to lose change and then it brings it back up to full charge and keeps it there. Its a great investment.
Rttix1337
10
Jan 20, 2014 03:50 PM
pimpassride99
Audio / Security / Video
20
Jun 17, 2007 08:04 PM
turbohondask
Honda Motorcycles
Jul 15, 2003 10:23 PM
ck279
Jan 16, 2002 12:08 PM
