How many of you have installed hondata IM gasket without leaks?
why? yours leaking? try using the liquid* like gasket sealer that Honda uses when mating surfaces and gaskets all together
ill be installing mine prolly this week. everything i read was good just making sure you get all of the old gasket off.
I havent installed it yet. But I while back I remember reading people were having issues. But now i am convinced that as long as you follow the helms for install and clean the matting surfaces very well it should work fine
Yep, there's no reason it won't work fine as long as you have a clean surface and torque the bolts down enough.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94vtirozguy »</TD></TR><TR><TD CLASS="quote"> you dont need to use sealant</TD></TR></TABLE>
was not planning on it
EX-T
10
May 4, 2014 08:02 PM
DJ Gurgla GSR
Jan 4, 2008 01:09 PM
