Cometic Head Gasket Thickness for B16 Turbo Setup?
Old Oct 22, 2007 | 09:59 PM
Barbantus's Avatar
Default Cometic Head Gasket Thickness for B16 Turbo Setup?
Hey guys, I'm putting together a B16A Turbo setup. I thought I'd get a Cometic head gasket while I had the head off. What thickness would you guys recommend? I am aiming for 250-300whp. I have TT Rods and SRP Turbo Pistons. They have .030 in 81, 81.5, 82, 83, and 85mm available on eBay. What do you guys think? Thanks in advance!
Old Oct 23, 2007 | 06:19 AM
morgan@synapse motorsport's Avatar
i think you should get a stock oem head gasket.
Old Oct 23, 2007 | 01:58 PM
90 JDM EF8's Avatar
Default Re: Cometic Head Gasket Thickness for B16 Turbo Setup? (Barbantus)
i put a cometic thicker head gasket on my boosted stock b16 thinking it would be good and my tuner told me after the fact that i could have gotten more power with a oem gasket ...so i would stay stock man
Old Oct 23, 2007 | 06:20 PM
Barbantus's Avatar
If that's what you guys recommend I think I'll go that way. Because I already have a OEM Head Gasket set. Would the OEM head gasket handle 300whp?
Old Oct 23, 2007 | 06:35 PM
NJIN BUILDR's Avatar
Default Re: (Barbantus)
The oem gasket is just as good as the Cometic.Some people prefer the oem over the Cometic anyway.If you already have a dished piston than the .030" thickness is good.If the bore is 81 to 81.5mm than you want the 81mm.
Old Oct 23, 2007 | 06:59 PM
Jay_Sensing's Avatar
I ran oem all year long in a nitrous motor spraying anywhere from 100-250 hp at it on top of the 210 it made on motor. No issues at all with OEM.
I have always used them in both nitrous and turbo motors with 0 issues up to the 500whp range.
Old Jan 12, 2008 | 04:00 AM
612tunerh22's Avatar
ya just go with the oem
Old Jan 12, 2008 | 08:13 AM
k_civic's Avatar
I need one to get low my compression with my old set up(nitrous- 11.5 - 1) Just change the OEM gasket to cometic 70mm w/o change my internals and run turbo with 25 psi...
Eghatchgsr8
Sep 19, 2014 02:24 PM
HPfreak
Sep 23, 2011 04:53 PM
Joeski99Si
Apr 23, 2009 05:24 AM
Joeski99Si
Apr 22, 2009 09:57 PM
racin_jayson
May 18, 2007 07:37 PM
