anyone know which plug this is?
I have an '89 ef DX with a b16a OBD-0 swap. I'm trying to figure out what this wiring plug is for....do i need it? the car runs fine without it in use....
looks to me like the IACV plug or the IAT sensor plug......it is a two wire plug right? IDK check those two sensors though cause they have the same connector.
probably connector for the DX tandem control valve - are the wire colors orange and black/yellow? - tandem control valve is only on the DPFI engines
its not tps. i was wondering the same thing. i also have that in my dads hatch. its a dpfi set up with obd0. it just has it laying back there just chilling.. i looked all over the place where that sensor could hook up to and it leads no where. I'm obviously missing something
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">probably connector for the DX tandem control valve - are the wire colors orange and black/yellow? - tandem control valve is only on the DPFI engines</TD></TR></TABLE>
That's what it is, the OP is just not reading the replies.
TPS is a 3 wire plug, that is a 2 wire plug...come on.
Knock sensor is also a 1 wire plug, that is a 2 wire plug, again...come on.
The OP said it was a DX, if anyone has ever done a MPFI swap you will see a left over plug, jlicrx had it correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9 JAMS!!! »</TD></TR><TR><TD CLASS="quote">that's your IAT sensor.
Wrong
Have you driven w/o the intake air temperature sensor connected?
This has been answered already, how about a lock.
</TD></TR></TABLE>Wrong
ninty1civic
Nov 11, 2009 11:33 PM
user 72830283
13
Sep 18, 2005 12:20 PM
