difference between 96-97 spec and 98+ ITR engines?
Old Oct 22, 2007 | 09:07 PM
2wheelhunter's Avatar
Default difference between 96-97 spec and 98+ ITR engines?
what is the difference? some sites say different things that arent the same as other site... 10.4:1 compression and 11.0:1 compression? 196hp, 210 hp? i dont know which is which and which would fit best into an '97 del sol si..
Old Oct 22, 2007 | 09:21 PM
egsleepercivic's Avatar
the numbers on this site are pretty accurate hmotorsonline.com
gl
Old Oct 22, 2007 | 09:33 PM
Default Re: (egsleepercivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">the numbers on this site are pretty accurate hmotorsonline.com
gl </TD></TR></TABLE>
they are very accurate but still doesnt show a difference
Old Oct 22, 2007 | 10:18 PM
gsr-2nr's Avatar
Default Re: (2wheelhunter)
there is no difference b/t the 2 engines just the body changes with the 98+ tegs. The ones tha say 210hp are jap spec but the usdm b18c5 is the same no matter what year its from
Old Oct 23, 2007 | 07:10 AM
Bignel00's Avatar
Default Re: (gsr-2nr)
actually gear ratio are a little different between the 96 and 98 type r . the 123 gears are the same . 4 and 5 are different and the final gear is different in the 98+ .
Old Oct 23, 2007 | 08:11 AM
_HANS's Avatar
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
Default Re: (Bignel00)
ummmmmmm?
difference in itr motors.
jdm itr 98+ 4.7 FD.
jdm itr 9697 are 4.4 FD
usdm itr 97,98,00,01 came with 4.4 FD
jdm itr 98+ came with 4-1 tubular header
jdm 96 97 came with cast header
usdm 9798 00 01 came with cast header
and cams. 98+ jdm better cams along with 00 01 usdm motors.
Old Oct 23, 2007 | 10:33 AM
gsr-2nr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bignel00 &raquo;</TD></TR><TR><TD CLASS="quote">actually gear ratio are a little different between the 96 and 98 type r . the 123 gears are the same . 4 and 5 are different and the final gear is different in the 98+ . </TD></TR></TABLE>
Yeah J spec engines have a different final drive not the US which I was referring to
Old Oct 23, 2007 | 11:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _HANS &raquo;</TD></TR><TR><TD CLASS="quote">
and cams. 98+ jdm better cams along with 00 01 usdm motors.</TD></TR></TABLE>
"better" how so? is it a lift thing or something else?
Old Oct 23, 2007 | 04:06 PM
redDAinteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _HANS &raquo;</TD></TR><TR><TD CLASS="quote">ummmmmmm?
jdm itr 98+ 4.7 FD.
basically all of that and also that 98+ ITR intake cams had 3 more degrees of duration over the earlier years. Not to mention the difference in compression ratios, All USDM ITRs only had a 10.6CR while 98+ JDM ITR had 11.1 compression.
Old Oct 23, 2007 | 06:17 PM
Default Re: (redDAinteg)
what is the compression on the 96-97 jdm itrs?
Old Oct 23, 2007 | 08:11 PM
SiR-G DC's Avatar
http://www.youtube.com/watch?v=34H2MCPEUV8
This video has what you want. Badass one too
Old Oct 23, 2007 | 09:17 PM
Default Re: (SiR-G DC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR-G DC &raquo;</TD></TR><TR><TD CLASS="quote">http://www.youtube.com/watch?v=34H2MCPEUV8
This video has what you want. Badass one too </TD></TR></TABLE>
interesting thanks!
Old Oct 24, 2007 | 08:22 AM
SiR-G DC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2wheelhunter &raquo;</TD></TR><TR><TD CLASS="quote">
interesting thanks! </TD></TR></TABLE>
Welcome, but searchimg goes a LONG way
killerpenguin21
Feb 13, 2008 06:29 AM
bmxer
Jan 31, 2008 12:06 PM
Chemi421
May 5, 2006 10:00 AM
jchung
Feb 28, 2004 08:39 AM
