tachometer reading too high after b16 swap?
Old Oct 22, 2007 | 08:26 PM
prettylew's Avatar
Default tachometer reading too high after b16 swap?
anyways. i did my b16 swap and the tach is reading like 500-800 rpms too high. anyone else ever have this problem?
Old Oct 22, 2007 | 11:45 PM
Zaakro's Avatar
Default Re: tachometer reading too high after b16 swap? (prettylew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prettylew &raquo;</TD></TR><TR><TD CLASS="quote">anyways. i did my b16 swap and the tach is reading like 500-800 rpms too high. anyone else ever have this problem?</TD></TR></TABLE>
What do you mean?
Old Oct 23, 2007 | 05:55 AM
prettylew's Avatar
sorry if i wasnt clear,. well for example, if my car is idling at 1000 rpms. the tach on the dash reads 1800.
Old Oct 23, 2007 | 08:59 AM
bodiez's Avatar
Hit the floor!
Default Re: (prettylew)
howdo you know its not accurate and maybe it is idling at 1800?
Old Oct 23, 2007 | 09:13 AM
jdm_titan's Avatar
best bet check ur grounds.
Old Oct 23, 2007 | 09:23 AM
prettylew's Avatar
Default Re: (bodiez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bodiez &raquo;</TD></TR><TR><TD CLASS="quote">howdo you know its not accurate and maybe it is idling at 1800?</TD></TR></TABLE>
trust me i know. ive been around cars and hondas too long to not know that its idling WAY below 1800. i dont need a TACH to tell me that. my ears are fine. all i know is that its idling somewhere around 1000. could be 1100 maybe 900 but definitely not at 1800 where its reading.
Old Oct 23, 2007 | 12:05 PM
Zaakro's Avatar
trust me i know. ive been around cars and hondas too long to not know that its idling WAY below 1800. i dont need a TACH to tell me that. my ears are fine. all i know is that its idling somewhere around 1000. could be 1100 maybe 900 but definitely not at 1800 where its reading.</TD></TR></TABLE>
then whats the problem?
Old Oct 23, 2007 | 12:13 PM
ludesrv's Avatar
Don't trust your ear. Trust a digital tech reading from your ignition wire.
Old Oct 23, 2007 | 06:25 PM
cars101's Avatar
i dont know but this may be a stupid way to tell but bring your rpms up to almost redline and see if its right if your redline is 10,000 say and its past that then your know your tach is messed up
Old Oct 23, 2007 | 06:38 PM
1RMDave's Avatar
Default Re: (ludesrv)
I agree, get a meter onto the plug wire and check it forsure.
Old Oct 24, 2007 | 03:47 PM
ch1nky's Avatar
did u check your accelerator cable? maybe its too tight or it cud be the idle valve.
Old Oct 24, 2007 | 03:49 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (cars101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cars101 &raquo;</TD></TR><TR><TD CLASS="quote">i dont know but this may be a stupid way to tell but bring your rpms up to almost redline and see if its right if your redline is 10,000 say and its past that then your know your tach is messed up </TD></TR></TABLE> That's a horrible idea, that's like if you have an itchy finger slicing your whole arm off.
Old Oct 24, 2007 | 04:44 PM
cars101's Avatar
Default Re: (***$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote"> That's a horrible idea, that's like if you have an itchy finger slicing your whole arm off.</TD></TR></TABLE>
lol it was just an idea.
Old Oct 24, 2007 | 08:00 PM
prettylew's Avatar
trust me guys my tach is at 2000 at idle. i KNOW when a car is at 2000. so i KNOW my tach is WAY off. its not like im sayin its off by 100rpms. its off by like 1000rpms. which is VERY easy to hear if your not a complete moron
Old Oct 25, 2007 | 03:25 AM
cars101's Avatar
tru wat about then gettin a aftermarket tach
Old Oct 25, 2007 | 06:09 AM
~sp33~'s Avatar
EFB055
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prettylew &raquo;</TD></TR><TR><TD CLASS="quote">trust me guys my tach is at 2000 at idle. i KNOW when a car is at 2000. so i KNOW my tach is WAY off. its not like im sayin its off by 100rpms. its off by like 1000rpms. which is VERY easy to hear if your not a complete moron</TD></TR></TABLE>
Settle down, theyre just suggestions.
I kinda agree with the redline tactic lol.
Old Oct 25, 2007 | 08:55 AM
loudandlow's Avatar
Default Re: (~sp33~)
borrow someone else's tach or get a cheapie $20 one and hook it up in your engine bay. should only take 5 mins to hook up cause your not mounting it. that should give you a reading you can trust. then you can put it back in the box and return it good luck and quit being a jackass to people that are trying to help you.
Old Oct 25, 2007 | 09:49 AM
prettylew's Avatar
im not being a jackass, its just everyones suggestion is "get a real tach"
but i know its off, u can BARELY here the motor its idling so low and nice. but the tach in my car is way high at like 2000 sometimes 2200.
Old Oct 25, 2007 | 10:00 AM
IT GUY's Avatar
does your tach return to zero when the car is off?
ever had the cluster out?
what distributor are you using?
Old Oct 25, 2007 | 02:07 PM
cars101's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~sp33~ &raquo;</TD></TR><TR><TD CLASS="quote">
I kinda agree with the redline tactic lol.</TD></TR></TABLE>
lol thanx it wasnt that bad of an idea hahaah
Old Oct 25, 2007 | 02:30 PM
akandok's Avatar
if you pay for shipping ill send you a free tach....
Old Oct 25, 2007 | 02:42 PM
loudandlow's Avatar
Default Re: (akandok)
Well if you won't listen to us and check it with another tach and you are already so f'n sure it's your cluster then STFU and get a new cluster already and quit wasting our time.
ps i love the new
Old Oct 26, 2007 | 05:47 PM
akandok's Avatar
Default Re: (loudandlow)
Old Oct 28, 2007 | 09:30 AM
1RMDave's Avatar
stock pr3 ecu? Go out and run it to 8000 rpm. Let us know at what rpm on the tach it said vtec on at.
1_slow_crx
Aug 18, 2006 01:05 PM
LilChuck
Jan 12, 2006 05:59 PM
Inisharu D
12
Feb 22, 2005 11:32 PM
JinDIESEL
Sep 23, 2004 12:24 PM
90civicB16
Nov 19, 2003 10:53 PM
