evap canister removal
Old Oct 22, 2007 | 05:59 PM
5280dc2's Avatar
Default evap canister removal
i have a '00 gsr and converting to obd1, from what ive read the evap control system can then be removed. is this correct? also do the old lines need routed out of the engine bay? searched it and everything i found was very vague
Old Oct 22, 2007 | 06:08 PM
so lazy's Avatar
Default Re: evap canister removal (5280dc2)
why remove it?
Old Oct 22, 2007 | 06:12 PM
5280dc2's Avatar
Default Re: evap canister removal (another-guy)
planning on a wire and brake line tuck this winter. head is off being built, and waiting for ecu to come. Figured nows as good of time as ever
Old Oct 22, 2007 | 06:19 PM
so lazy's Avatar
I'll take some pictures for you. I'm currently doing a tuck on a delsol right now. I'll see where the lines can be routed to.
Old Oct 22, 2007 | 06:25 PM
5280dc2's Avatar
that would be helpful. thanx. doing the tuck yourself?
Old Oct 22, 2007 | 06:41 PM
so lazy's Avatar
yes doing it myself.. the tuck is done.. just waiting for the motor to get back from the machine shop had the block notched for the rods.
Old Oct 22, 2007 | 06:54 PM
5280dc2's Avatar
Default Re: evap canister removal (so lazy)
know of a good diy tuck thread? looked at a couple but mostly pics. a friend of mine does them on supras, but has not done a honda.
Old Oct 22, 2007 | 06:55 PM
5280dc2's Avatar
still looking for an answer for original post. anyone?
Old Oct 22, 2007 | 06:56 PM
so lazy's Avatar
Dude I really didn't look at no1 else's tuck. I just started doing it on my own. I've worked for honda for 3years and I've pulled a bunch of dashes out while I was there. Did a bunch of wiring back in the days also. I'm currently building engines and cars for people on the side as a hobby.
Old Oct 22, 2007 | 07:12 PM
5280dc2's Avatar
look foward to the pics
Old Oct 22, 2007 | 09:09 PM
Gunns's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5280dc2 &raquo;</TD></TR><TR><TD CLASS="quote">still looking for an answer for original post. anyone?</TD></TR></TABLE>
I have removed it from my OBD1 converted B series.
Pros
Bay looks cleaner
car runs just fine
Cons
Bad for the enviroment
Harder to pass emissions test
I MIGHT post some pics later.
Old Oct 23, 2007 | 03:42 PM
5280dc2's Avatar
Default Re: evap canister removal (Gunns)
no check engine light? from what ive read its not even used on obd1. also read you need to route the lines down and out of your engine bay to avoid fumes in the cabin. pics?
Old Oct 23, 2007 | 03:43 PM
5280dc2's Avatar
nevermind on the pics. just read the bottom of your post. sorry
Old Oct 24, 2007 | 03:23 PM
Gunns's Avatar
No engine light from the removal.
Only line you have to worry about fumes is right inline with the driver. Its where the fuel lines run into the engine bay. There is a return line for fumes. I just turned it to face under the car. I have never had the smell of gas on my car.
Old Oct 26, 2007 | 07:21 PM
5280dc2's Avatar
thanks for the help, just finished and looks good.
gorillaglue#4
36
Mar 15, 2019 09:29 PM
Paul-R
Nov 13, 2008 07:26 PM
jadugartir
Jun 9, 2006 09:24 PM
DocSean
Welding / Fabrication
16
Aug 14, 2005 03:34 PM
RTW DC2R
Feb 15, 2004 08:50 AM
