LS Engine Swap, GE 84mm LS/Vtec HG, AEBS LS/Vtec Head studs, GSR LSD, Catch can
PRICED TO SELL!! WILL TAKE REASONABLE OFFERS AND TRADES!!!
Hickam Series rear bumper diffuser
Perfect for Honda/Acura or other makes. Measures 46" by 4".
$65 for anodized black
Will also have a couple sets that measure 19" by 4" for the CRX that will have just the holes in it.
<U>FINALLY PICS OF THE ANODIZED!!!</U>
Greddy RS BOV Mint condition, comes with box and t fitting that came with it new $125
(4) Fuel Clinic 650cc Injectors all 4 with resistor box $175
3" Resonatori think it is 24" long. BRAND NEW $65
GE 84mm LS/Vtec conversion headgasket NEW NEVER USED $85
GMB waterpump, Tensioner and Timing belt all for GSR $90
Gauge cluster dual gauge pod mounts (2) 52mm gauges around the gauge cluster in a 94-01 Integra $25
Catchcan for your battery tray cut down your stock battery tie down hooks and it comes with a catch can brace, can add fittings or whatever you want. was using regular rubber hose, but -AN line can also be used SOLD
Can also custom fabricate a catch can with any dimensions you want. Just PM me
1996 Integra LS Head, good condition, took it off of a running motor $75
1995 Integra LS Head Has CROWER Dual valve springs and Titanium retainers installed. NEVER OVER REVED. $300
(2) B-series manual starters, both WORK!!!, $65
Stock 1996 LS block, COMPLETE, was converted to obd1 $345
LS Hydro tranny, NO GRINDS AND SHIFTS PERFECT! $370
Axles Non ABS axles for 94-01 integra B-series $145
Engine harness OBD1 $75
Driver motor mount 94-01 integra $30
Tranny mount 94-01 integra $30
Shift linkage, 94-01 integra b-series $70
LS Dizzy obd1 $100
ARP LS headstuds $65
Half Shaft for b-series $65
LS oil pan tapped for return line $35
94-01 integra
LS gauge cluster, manual with 130k. $60
94-01 Integra Glove box $20
94-01 Integra Blower, should fit 92-95 civic too $20
94-01 Integra Black shifter console with carbon fiber overlay $20
94-01 Integra Black shifter console $20
94-01 Integra Gauge cluster bezel $10
94-01 Integra Climate control with carbon fiber overlay $20
94-01 Integra Dash kicker panel under steering column $10
92-95 civic Dash wire harness $30
12" L5 solobaric sub in good size box, fit perfect in the back of my hatch and Kicker 750.1 mono amp. Only used for a month then took it out. Have everything to hook it up $300
AEBS LS/Vtec conversion head studs $85
LS Tranny has Phantom Grip LSD, needs case $245
PM me if you want a turbo mani, give me details on what you want and i will get you a price
Modified by HickamHatch at 10:25 PM 12/3/2007
LS Dizzy obd1 $100
94-01 integra
