WTB k series swap parts
Just as title states i need everything you could need to swap a k in to a eg
Will take about anything i just don't want type s trans ep3 preffered.
Show me what you got
05 Type S axles - 150
05 shifter box and cables - 200
05 oem clutch assy. and flywheel (3k miles) - 100
Type S arp head studs (about 10 miles on them) - 100
Hytech RBC manifold and BDL 70mm TB w/ sensors (stock injectors/rail) - 700
02 Type S cams, springs, retainers - 200
05 A/C compressor - 150
05 P/S pump - 50
05 Type S head (damaged) - 400 SOLD
05 Type S block (damaged) - 600 shipped!
05 Type S head - 600 SOLD
05 Engine harness and charge harness w/ fuse box - 250
I have a 05+ style 5 spd tranny, also. (4.7 final)
If you want everything, I could sell you my swap for about 9k. If you have any interest let me know, and thats not a stock type S you would be getting.....
05 P/S pump - 50
Its an 02 rsx type S
6 spd 4.7 lsd tranny
IPS K2 cams w/ eiback EVS valve springs and retainers
DTR/SSR 4-1 stainless header
ACT extreme pressure plate w/ street clutch disk
ACT cromoly 9 lbs flywheel
DSS stage 2 axles
Kpro
Revo short shifter box and linkage (skunk2 6spd ****)
RSX throttle cable
Karcepts shifter kit
Karcepts radiator bracket
Hybrid-Racing motor mounts (full billet aluminium)
All fuel lines needed already pre-cut w/ fittings
AEM fpr with liquid filled guage
Hybrid-Racing interior harness
Both radiator hoses
Pretty much I am going to take the swap out of my car and ship it to you. I feel that is a reasonable price if you put together what are getting, and the simplicity of actually get everything, and I mean everything to put the swap in the car.
Modified by AwdEi at 10:18 PM 10/23/2007
DSS stage 2 axles
Kpro
RSX throttle cable
Both radiator hoses
