STOCK CRANK OR AFTER MARKET???
I cant find anything on this so I am making a post. I cant find a crank my machinist likes he has turned away three cranks that I have brought him. He say he will not grind them down it makes them weak. First my setup, 82mm Benson GSR block eagle rods and je pistons. The car will be daily driven boosted and will probably see somewhere around 600 HP on occasion. So my question is should I hold out for a GSR or Type R crank. Go get LS eagle rods and a LS crank. Or buy a stock eagle crank witch he says he can get me for 450, brand new. I just want my motor to hold up because I drive alot. Thanks Jordan
Are you bringing him cranks that have already spun bearings? Cause my machinist wont touch a spun crank either.
Get yourself a good gsr crank,preferably one that hasnt spun a bearing.Have him polish,balance and service the crankIf you bring it to him with ***** in the journals and he gives it back with ***** in the journals and not set screws,take it back,cause more then likely the crank wasnt cleaned the right way and will cause a spun bearing..
Not saying your machinist work is questionable,but 75% of machinist just do maintenance work..
He didnt like the grooves in two of them. ( you could stick you fingernail it ) The other one had a spun bearing. Thanks for the info so far.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlakeJ53 »</TD></TR><TR><TD CLASS="quote">He didnt like the grooves in two of them. ( you could stick you fingernail it ) The other one had a spun bearing. Thanks for the info so far.
Sounds like you have a good machinist. Don't ever turn/grind a Honda crank or use one that has spun a bearing.
</TD></TR></TABLE>Sounds like you have a good machinist. Don't ever turn/grind a Honda crank or use one that has spun a bearing.
