fuel filter help
Old Oct 22, 2007 | 01:13 PM
HASUNA91's Avatar
Default fuel filter help
i looked everywhere on here i cant find nothin... im wondering where the fuel filter is on a 92 civic and if its hard to replace. thanks in advance
Old Oct 22, 2007 | 01:31 PM
HASUNA91's Avatar
Default Re: fuel filter help (HASUNA91)
cmon guys help me out
Old Oct 22, 2007 | 01:56 PM
crxricer66's Avatar
should be on ur fire wall next to the battery. there is one line going in, one comeing out that goes to ur fuel rail. its simple.......
Old Oct 22, 2007 | 02:23 PM
ke98248's Avatar
This is it:
Old Oct 22, 2007 | 02:25 PM
ke98248's Avatar
The fuel filter should be replaced 1) every 4 years or 60,000 miles, whichever comes first, or 2) whenever the fuel pressure drops below 40-47 psi, with the fuel pressure regulator vacuum hose disconnected and pinched, after making sure that the fuel pump and the fuel pressure regulator are OK.
1. Disconnect negative battery cable.
2. Place shop towel under and around fuel filter.
3. Relieve fuel pressure, by removing gas cap.
4. Remove 12 mm banjo bolt and 14 mm fuel feed pipe (use flare wrench) from fuel filter.
5. Remove fuel filter clamp and fuel filter.
6. Use new copper washers, when assembling.
7. Tighten banjo bolt to 16 lb-ft, service bolt (middle of banjo bolt) to 11 lb-ft, and fuel feed pipe to 28 lb-ft. Clean flared joint of high pressure hoses thoroughly before reconnecting.
CAUTION: Only change fuel filter when the engine is cold. Keep a Class B fire extinguisher ready. No smoking or open flames allowed (e.g., gas hot water heater, dryer, or furnace). Keep tools a safe distance from battery. Wear safety goggles.
Old Oct 22, 2007 | 04:27 PM
macdaddydelux's Avatar
Default Re: fuel filter help (ke98248)
yea thats it, its not hard to replace though just a couple of bolts ...when u losen up the bolt coming out it will shoot a little gas out..dont worry just crack it loose & let the system presure down before u take it all the way out.......after u change it turn the key on & let the pump fill it back up before u try to crank the car
Old Oct 22, 2007 | 04:33 PM
ke98248's Avatar
Default Re: fuel filter help (macdaddydelux)
That's why I posted directions above your post.
martn53
Nov 10, 2009 01:24 PM
magic hat #9
Jan 9, 2009 07:23 AM
green eyed bandit
Aug 15, 2007 11:27 AM
SiYouLater
Apr 14, 2007 11:42 AM
