Anyone know if 90-93 Integ rear disc fit 88-91 CRX ?
have you tried it yet ? I have the complete assembly home never tried it though, wondering if anyone has ?
thanks,greg
thanks,greg
my cousin told me yes u can use 91 teg rear dics on the EF civics. i beleive him so i was getting some soon... i am pretty sure they do. but get some more input about this ... so i make sure too jejejej
It fits...just need to get a 91 e-brake cables and you're pretty much set. you also have to use the brake lines from the new assembly, so make sure they're in good shape. Plug and play.
greg
ok, this is a situation. i have a 91 CRX SI left rear trailing arm, and i can get a 90 integra LS right rear trailing arm. is there any difference between the crx and integra parts? i can swap the rotors, and calipers to get a matching set.
I just took the hub off my '91 integra trailing arms and put them on the crx trailing arms. There is 4 or 5 hex bolts and a big 21mm bolt in the center. It is working great. If anyone has loads of money, the hubs are $100, calipers are $100, and e-brake cable ~$60 from honda per side. It's a bit pricey but it would all be brand new.
what year trailing arms did you use? i thought the bolt pattern was different from 88-89 to 90-91. does the integra stuff bolt onto the 89 trailing arms?
I'm using 90 teg brakes on all fours. I replaced the trailing arm bushings since they we out (warning this makes the install very much harder since the bushing is alot more stiffer). Also you have to use your stock toe adjusment arm, the Teg one is too short. I'm also using the Teg e-brake cables, I just manipulated them to work (the holes on the floor where the cables protrude through, I ran the driver side through the the passenger hole and vice versa) by doing this you won't need to buy the Si cables. God how they work WAYYYYYY better than the Jesus HF brake set-up, now I don't have to pray to Jesus anymore that I'll stop in time.
Bryan
Bryan
MikeySpec
Aug 31, 2004 06:47 PM
