will the 96-2000 civic suspension fit dc2/4's?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98PAITR »</TD></TR><TR><TD CLASS="quote">I'm pretty sure it won't.
I know some 92-95 civic springs can swap to the teg chassis.</TD></TR></TABLE>
yea i knew that...but the struts look similar so i had to ask...sweet avatar btw
Most of the suspensions fit. I have used the steering knuckles, shocks, and springs from integra on to my civic before. The only thing that does not work are the control arms...
can anyone confirm if it fits or not? i know eg and dc suspension is compatible. but how about 96-00 civics?
As a last resort for a quick repair, I used '96-'00 Civic rear springs/struts on my '94 Integra. The main difference is the width of the bracket on the bottom of the strut which attaches to the LCA - in my case, I heated the bracket with a torch [DANGEROUS, I don't recommend doing this unless you're a professional] and spread it outward, then bolted everything together as normal.
I'm not sure about front struts, though they seem to be identical at first glance. LCAs should be the same, excluding thickness [EKs are thinner I believe].
Mr. Softee
Jul 19, 2002 02:48 PM
Rhetoric
Feb 8, 2002 03:53 PM
