rota slip streams
alright im thinkin of buyin rota slipstreams but where can i get them ebay has it but i dont not really sure if it would fit for a 15 inch
this is the size for the one on ebay! is it correct i dont wanna purchase if it doesnt fit lols but if anything anyone know any sites i can purchase it
Bolt pattern : 4x100
Offset : 40mm
Offset : 40mm
Uh...i have a set of 16" Rota Slips. I've seen plenty of these with 15" versions. Yes. As long as it's a 4x100 bolt pattern, they will fit. Go with the mentioned tire size above.
you have 16 in do they look better than the 15 in ? im usin h&r springs 2.0 drop in the front and 1.75 in the back should i go with the 15 or 16? i just dont want tire rubbin on the fender
Go with 16". IMO, 15's are a bit too small. Tires will be a bit more expensive since you'll probably need to go with a thinner tire wall. I'm running a 205/40/16 tire. Ride will be a bit stiffer as well.
I do not want to start an argument, but 15's are lighter, the ride is better, and with the right brand tires (Falken Azenis) you can still get just as good of handling that the 16's afford. They are also cheaper. I do agree that on certain cars, 16's do luck better though. Also, just so you know...195/55/15 will also work as that is the stock integra 15" size. Good luck either way you go!!!
Modified by weavertime1 at 9:42 AM 10/22/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR »</TD></TR><TR><TD CLASS="quote">16s do look better imo but for performance reasons and tire pricing id say go 15s. forget the 195/55/15 just grab you the 205/50/15</TD></TR></TABLE>
Oh without a doubt the 205 50 15 is the way to go!!!
