Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Camber Kit
Old Oct 21, 2007 | 09:40 PM
JTaudio0212's Avatar
Default Camber Kit
I am looking at getting springs and I was wondering how many people have lowered their cars without a camber kit? (I am guessing a lot)
Someone told me that if I lower the car beyond an inch I "have" to get a camber kit, which I don't totally believe. I am guessing it's one of those "recommended" things to do.
Is there a certain drop you can go without needing it?
I know there are downfalls without using a camber kit (uneven wear and such) but I was just wondering if its a must.
Also, I used the search function and only found one thing about using a camber kit and it didn't seem to answer any of my questions.
Thanks Guys, JT
Old Oct 21, 2007 | 10:06 PM
originalg00kster's Avatar
Default Re: Camber Kit (JTaudio0212)
well im running my sportlines with no camber kit right now..but im going to get it..my rear is about -2 off...where its supposed to be in the green. so just so i dont eat up my tires..im going to get a rear camber just to be on the safe side..but i notice no wear at all what so ever yet.
Old Oct 21, 2007 | 10:26 PM
a1staecksauce's Avatar
From: Westminster/Huntington Beach/Seal Beach, CA, United States
same here. i have eibach sportlines, which about 1.4 inch drop, and i have no camber kit. the camber falls just within the OK area before you need a camber kit. i havnt noticed any uneven wear or anything major.
Old Oct 22, 2007 | 01:01 AM
omega1n's Avatar
Default Re: Camber Kit (a1staecksauce)
Im in the process of lowering my car as well. I looked into the camber kit and got a quote at a local performance shop for $20 a wheel. They said I only needed it for the back... I don't mind paying the extra $40.
Old Oct 22, 2007 | 06:22 AM
Default Re: Camber Kit (omega1n)
Sweet guys, thanks a lot for your responses...
I was debating on the Pros and the Sportlines, I would like to go eibach... I just can't stand the wheel gap
Old Oct 22, 2007 | 06:39 AM
ednksu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omega1n &raquo;</TD></TR><TR><TD CLASS="quote">Im in the process of lowering my car as well. I looked into the camber kit and got a quote at a local performance shop for $20 a wheel. They said I only needed it for the back... I don't mind paying the extra $40.</TD></TR></TABLE>
i would love to know where they got those prices from. a camber kit on the back wheels is around $250 the fronts are around $30.
http://www.corsportusa.com/sto...24e70
Old Oct 22, 2007 | 07:12 AM
RICO_'s Avatar
NO MERCY!
Default Re: Camber Kit (ednksu)
Here's a somewhat mediokre pic of my Pro kit drop.......no camber issues here.
Old Oct 22, 2007 | 09:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ednksu &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.corsportusa.com/sto...24e70</TD></TR></TABLE>
AHHH I knew it! I was confused because everywhere I checked for the rears they were 250... but it is what it is...
Old Oct 23, 2007 | 12:34 AM
omega1n's Avatar
The part they quoted me for was for a Ingalls Engineering Fastcam Camber kit 35420. Went to the Ingalls site and the MSRP is $20. http://www.ingallseng.com/parts/35420.htm
I also found them on other sites for $12...
Old Oct 23, 2007 | 03:39 AM
ednksu's Avatar
I also found them on other sites for $12...</TD></TR></TABLE>
those are for the front only. not the back.
Old Oct 23, 2007 | 03:45 AM
omega1n's Avatar
My mistake, you're right.
Old Oct 24, 2007 | 06:07 AM
PhalanX's Avatar
Default Re: Camber Kit (RICO_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ednksu &raquo;</TD></TR><TR><TD CLASS="quote">i would love to know where they got those prices from. a camber kit on the back wheels is around $250 the fronts are around $30.
http://www.corsportusa.com/sto...24e70 </TD></TR></TABLE>
I was thinking the exact same thing.
Right now Im dropped on Tein S-Techs and I forget what my actual camber rate is, but its right around the 'ok' mark. Im going to get a camber kit at some point anyways just to be safe. But like everyone else, i dont notice any uneven wear... yet.
But everything Ive seen is like $250 for the rear alone. I wanna know where they got $20 per wheel from.
edit: my bad.... guess i shouldve read the rest of the thread.
Modified by PhalanX at 10:30 AM 10/24/2007
Modified by PhalanX at 10:31 AM 10/24/2007
Old Oct 24, 2007 | 08:26 PM
blue2ksi's Avatar
if your going to do anything to your suspension, do it to your alignment. there's no point in modifying your suspension without changing your alignment specs.
Old Oct 24, 2007 | 11:09 PM
06civicracer's Avatar
this is what i been told:if you go 1.5" or more you will need a camber kit and alignment
Old Oct 24, 2007 | 11:51 PM
Aco512's Avatar
having an aggressive drop such as the sportlines
i highly recommend a camber-kit
its a noticable difference, especially the rear tires
install them the same time you install your spring/suspension
it will be much easier and its fairly affordable
Old Oct 25, 2007 | 02:10 PM
blue2ksi's Avatar
Default Re: (06civicracer)
this is what im telling you. if you want anything out of your suspension, you will have to change your alignment with the use of camber kits. there is no compromise in tuning your suspension.
for example, i put front camber bolts on my stock suspension to get to -2 camber and it helped drastically at the race track.
Old Oct 25, 2007 | 03:19 PM
Nsane's Avatar
i have the sportline lowering springs on my FA5. The Camber was off -3.25 and -3.50. so my rear tires ate the dust after ~3500 miles, they were cupped really badly, vibrated on the highway and were very noisey @ 70 mph.
i would say camber kit is a must. i bought the skunk2 rear camber arms, no complaints other than they are truely a PITA to adjust... so much work
Old Oct 25, 2007 | 03:25 PM
I:_Drive's Avatar
Default Re: (blue2ksi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue2ksi &raquo;</TD></TR><TR><TD CLASS="quote">this is what im telling you. if you want anything out of your suspension, you will have to change your alignment with the use of camber kits. there is no compromise in tuning your suspension.
for example, i put front camber bolts on my stock suspension to get to -2 camber and it helped drastically at the race track. </TD></TR></TABLE>
lets be honest here for a second. you are among the 3% of people on 06+ that actually track your car. most people are just going for looks. so things like this really dont matter to them.
Old Oct 25, 2007 | 04:58 PM
Aco512's Avatar
Default Re: (I:_Drive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I:_Drive &raquo;</TD></TR><TR><TD CLASS="quote">
lets be honest here for a second. you are among the 3% of people on 06+ that actually track your car. most people are just going for looks. so things like this really dont matter to them.</TD></TR></TABLE>mine is a daily (been to the track twice)
as i've said, what is stopping people from getting a camber-kit?
saves the threads on your tires and it keeps it from looking awkard
still part of the looks catergory if that's what people are going for
FLACO EM1
Nov 27, 2008 01:39 PM
t.phan
Dec 23, 2007 03:33 PM
imonx850
Suspension & Brakes
Mar 14, 2005 08:47 AM
sherfield2002
Oct 29, 2004 08:43 PM
