Transmission Problem, First startup
Old Oct 21, 2007 | 08:21 PM
powerdbygarrett's Avatar
Default Transmission Problem, First startup
when the car is off the trans goes through the gears no problem, then once i start it, its next to impossible to get into gear. my pedal has a little play in it but nothing more than it was before the swap. what could be causing such a problem? master cylinder? slave? if it matters the motor is built and im running an action stage 5 i think clutch with the same action pressure plate? im really hoping this is a minor problem that could be fixed but ready for the worst.
thanks!
Old Oct 21, 2007 | 08:54 PM
MLBZ521's Avatar
Default Re: Transmission Problem, First startup (powerdbygarrett)
Do you have fluid in the Clutch System?
Is the Clutch System working? Do the Slave move when the pedal is pushed?
Old Oct 21, 2007 | 10:19 PM
Default Re: Transmission Problem, First startup (MLBZ521)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLBZ521 &raquo;</TD></TR><TR><TD CLASS="quote">Do you have fluid in the Clutch System?
Is the Clutch System working? Do the Slave move when the pedal is pushed?</TD></TR></TABLE>
I know there is fluid in there, I refilled it after bleeding it. I'm thinking its the clutch system too. I did'nt think to check if the slave moves when the pedal is pushed in, im going to have to check that out in the morning.
I was thinking it was something along the lines of the clutch not engaging all the way when the pedal was pressed, just needed a someone to tell me.
So if the slave doesnt move when the pedal is pressed in then I need a new slave cylinder correct?
It wouldn't be the master because there is no dripping inside the cabin right?
Old Oct 29, 2007 | 09:03 PM
ok got it fixed. changed out the slave and it started working perfectly
Old Oct 30, 2007 | 11:54 AM
ChrisRicketts's Avatar
Default Re: (powerdbygarrett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerdbygarrett &raquo;</TD></TR><TR><TD CLASS="quote">ok got it fixed. changed out the slave and it started working perfectly</TD></TR></TABLE>
Thank God!- I'm happy for you....
The second i saw your thread it gave me a flashback, and then i saw you have an Action stage 5 clutch and it made my flashback even worse, but now that you have it fixed, i'm relieved for you....
here's what i mean by flashback......
https://honda-tech.com/zero...age=1
~~DOODLOOOO~~~~DOODLOOO~~~~DOODLOOO~~~
Modified by ChrisRicketts at 3:06 PM 10/30/2007
eshed
Oct 18, 2013 11:00 PM
importfanatic17
Jan 1, 2007 10:00 PM
Mwsol
Dec 22, 2004 12:25 AM
thehatchninja
Nov 15, 2003 09:01 AM
94dxt
May 8, 2003 06:25 PM
