grounds
Old Oct 21, 2007 | 07:15 PM
jweeks's Avatar
Default grounds
ok, ive been searching around and have found some answers but not all, im currently doing a dohc zc swap in a crx, the car came dissembled and all the wiring to the fuse box under the hood are taken off, im wondering what all grounds are need for this swap, so far we have the valve cover the battery. I dont think the thermos stat is grounded, if it wasnt would it enable me from getting power. dont have the starter yet, should there be more than one for it?
Old Oct 21, 2007 | 10:26 PM
Fezzie's Avatar
Default Re: grounds (jweeks)
you need valvecover ground, thermostat ground and tranny ground
Old Oct 22, 2007 | 04:24 AM
92hatchboi's Avatar
Default Re: grounds (Fezzie)
thermostat is a must bro it will cause ur car to bug out and back fire and **** make sure thats grounded it a little circle wire one ur engine harness around the area where the thermostats at.TWO WORDS GROUND IT!
Old Oct 22, 2007 | 06:58 AM
thesmogman's Avatar
You also need one to the chassis/body.
Old Oct 22, 2007 | 07:58 AM
jdm_titan's Avatar
will it really bog out(back fire)??
QuickStyle
May 26, 2007 03:57 PM
crxdriver89
Sep 17, 2005 07:44 AM
Fuzion
Sep 3, 2004 12:08 PM
coot_er
May 18, 2004 01:19 PM
