92-95 Civic Seats in a 90 Hatch
Old Jun 21, 2002 | 12:51 AM
No More Civic's Avatar
Default 92-95 Civic Seats in a 90 Hatch
Anyone done this? If so, how much of a pain in the a$$ is it?
Old Jun 21, 2002 | 01:09 AM
Magick211's Avatar
Default Re: 92-95 Civic Seats in a 90 Hatch (SlowCivicDX)
I gave it a try lol. They would never sit like i wanted them too but im sure with enough time it can be done,
I have 93 Ls seats in mine now i like them alot better than 92-95 civic seats
Old Jun 21, 2002 | 06:18 AM
USDM 4G VTEC's Avatar
i guess u going to have to swap the rails and everything to see if they do fit..
Old Jun 21, 2002 | 07:34 AM
virginia_dude's Avatar
Default Re: 92-95 Civic Seats in a 90 Hatch (JDM EF9)
well In a '89 Hatch I had to make adapter brackets to fit the seat to the stock rails. The '89 and the 92-95 dont have mounts in the same place, the outer rail is about 2-3 inches from where it needs to be. The rear can be made to fit much easier. I have th full set from a '93 in my '89 hatch. Was told you can use the older base with the new backs and use the new cover on the old base. I didn't do that since my base was a mess. Foam was disintegrating. and the foam wouldn't swap since pan shape was different. If you are into some fabrication, it isn't real hard some angle iron some 1X1 or 1X2 box stock (use it on one side so seat sits level)something to cut and grind with and it can be done in an afternoon. I used the '89 barckets and modified the '93 seats so I could bolt the adapter I built to fasten one to the other. and fit stock floorpan. I assume the '90 seats aren't substantialy different than '89 seats. except for seat belt mounts. The '92-95 seats have both mounts on the outer sides of the seat, the '89 had the indide mount at the seat edge but the outside mount is about 4 inches in from the seat edge. so you see why custom adapter is needed. Dont drill through the pan to bolt the new seat up, you don't want to go through the windshield with your new seat strapped to your *** when you hit something do you.
[Modified by virginia_dude, 11:58 AM 6/21/2002]
Old Jun 21, 2002 | 08:06 AM
Cereal_Killer's Avatar
Default Re: 92-95 Civic Seats in a 90 Hatch (CivicBoyZC)
hey how did you get your teg seats in? do they sit higher? what rails did you use? i currently have a set of 91 seats and may put them in this weekend. any help would be appreciated.
99_dc2
Oct 5, 2005 01:16 PM
Got Utensils
Mar 29, 2004 07:22 PM
kevinm1981
12
Nov 11, 2003 11:26 AM
1slowassr
Mar 26, 2002 07:45 PM
Nytecomm
Mar 10, 2002 12:30 PM
